Question about Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool is leaking from the bottom during
We have a whirlpool duet sport front loading machine. It has been leaking for the past couple of days when we use the machine. The machine does complete the cycle. The water is coming from underneath the machine. checked the hoses in the back they appear fine and in tact. help.
  • charlezzange Jul 17, 2009
    No it is quite large...it appears it is all the water from the spin/rinse cycle.
  • John Riley May 11, 2010
    is it just a small puddle of water?
  • 5,911 Answers
The only way to determine where the leak is coming from is to remove the lower kick panel directly below the door. Remove the panel by removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then off. If you prop the front feet up this will give you better access (a 2 x 4 works well).
With the panel removed inspect the rubber door bellow. If the front counterweight (gray concrete block on the front of the tub) is wet, the bellow is leaking. Pull the rubber folds back and look for any rips or tears. If the bellow requires replacing, or if you need to simply tighten the clamps, the following link will explain how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
NOTE: Check the plastic dispenser hose on the left hand side of the bellow to ensure it is inserted all the way through the rubber to the flange joint. Sometimes this dispenser hose will slip behind the bellow and allow water to seep inside the cabinet of the washer.
Check the drain pump to ensure the filter cap is secure and not leaking. The pump is in the front directly below the wash tub. If the pump IS leaking, make sure the filter cap is tight and all hose clamps are snug. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Check all hoses the run from the wash tub to the pump, and from the pump to the standpipe at the wall for any signs of cracks or tears.
If the leak is coming from the center portion under the tub, the tub seal is breached and needs to be replaced. This is not an easy repair and will require some extensive disassembly to repair. (Cross that hurdle when the time comes).
Any replacement parts you may need can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. You can use any web source you like, but these I have found, offer great service with competitive pricing. Shop all of them for the best prices. Hopefully you won't need any parts.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 17, 2009
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front loader is leaking water out the bottom during wash cycle
1- check the drain pump.
2- check the connection between control board and power board.
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool duet sport front load washer is fairly new (2008) now it has started dripping water during the cycle under the front of the machine. any suggestions would be helpfull.thank you
check tub boot for any tears in lip that seals to door zippers etc. can tear this.also sometimes water can leak from pump cleanout.you would need to remove bottom panel to check this
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET GHW9100 FRONT LOAD
Take the top off the unit,and check the springs..there are 4 on top and 4 on the bottom..make sure they a attached..and tighten
Jan 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
358 people viewed this question
Dan Webster
Dan Webster
Sal De
