Question about GE Dryers
Drying time is longer than usual.
GE Two Cycle Gas Dryer (M# DDG5180RALWH/S# HH303098G)
A couple of weeks ago noticed that drying time is longer than usual despite dryer being "hot" inside the barrel. I cleaned the lint catch and underneath it, inside where the air flows down beneath the barrel. I also checked and cleaned the exhaust tube and outlet pipe in the wall (not very dirty to begin with).
Any thoughts/ suggestions are appreciated. Thank you for your time with this matter.
Dave
  • GE Master
  • 3,382 Answers
Check if you have a reasonable amount of airflow when it is operating. You may have a broken connection in the joint or a problem with the dryer fan,
Posted on May 17, 2017
jumptrout51
  • 3361 Answers
SOURCE: Gas dryer - Not drying
Replace the gas valve coils.
Posted on Apr 07, 2009
  • 4088 Answers
SOURCE: The dryer isn't drying properly. It gets hot its
Make sure the drum is turning and the blower is functioning. Vacuum out all air passages including the hose going to the outside vent. Remove the lint trap, and wash it in hot water and detergent to clean away fabric softener deposits from the screen. If the motor is not running, find out why.
Posted on Nov 21, 2009
BMT60
  • 126 Answers
SOURCE: filter only catches about 1/3 of the lint. The
YEP! IF IT CAUGHT IT ALL THEN IT WOULD NOT BE ENERGY EFFICIENT. YOU ALSO MAY ALREADY BE MISSING THE FELT AT THE BOTTOM OF YOUR LINT SCREEN.
Posted on Apr 24, 2010
  • 244 Answers
SOURCE: Lint and dirt beneath the filter. I clean the
You can find dryer cleaning kits that contain different size and shape brushes at different variety stores. I bought mine from Fuller Brush. Ross stores also carry the cleaning kits. You'll be amazed at the "stuff" that comes out when you use these brushes. The handles are long enough to go waaaaay down in the exhaust hose to loosen and remove the lint. I also like to go to the outside exit and clean with the brushes. There is a lot of build up in that area also.
Once you've brushed out as much as you can, then you can vacuum and get all the gunk you loosened as you were cleaning.
I hope these suggestions help. If so, please let Fixya know by rating my solutions.
Posted on Nov 23, 2010
noranda21
  • 1547 Answers
SOURCE: The dryer appears to be overheating. The top of
Excess lint can also cause a dryer to get too hot. Again, you should check the filter and the vent for lint. Clean them if needed. Another thing that could cause a dryer to get too hot is a bad blower. This would need to be replaced if damaged. You should also, never use white plastic vent. This can cause your dryer to overheat and also be a fire hazard.
If you are not already a repairman, there will be some problems that arise that you cannot fix. The idea is to know what to look for and to fix whatever problems you can. This way, you don't purchase a new one or call a repairman unless it's necessary. When making repairs, always unplug your clothes dryer for safety. If parts are needed, make sure you have your manufacturer and serial number with you before going shopping. This will help ensure that you buy the right parts and save you another trip to the store. Most of us are intimidated at the thought of dryer repair. Just keep in mind that a lot of common dryer problems are simple (excess lint) and can be fixed by anyoneIf the dryer heats when the Fabric Care/Temperature switch is set to AIR FLUFF (No Heat), check the following:
-HARNESS/CONNECTION
-HEATER RELAY
-FABRIC CARE SWITCH
-EVEN HEAT CONTROL
Procedure:
1. Perform the Fabric Care/Temperature Switch Test
2. Set the following configuration:
Door- must be closed
Fabric Care/Temperature switch- AIR FLUFF
Timer- TIMED DRY
3. Press the PUSH TO START switch
a. Check voltage on Heater Relay. If P3-1 to P3-2 is 0VDC, replace the Heater Relay
b. If P3-2 is 48VDC, replace the Even Heat control.
Posted on Dec 05, 2010
Buzzing every 30 seconds
you can remove the buzzer its a small black round peice with a small hole in the middle on the main ic .p.c.b bord but if its buzzing there might be a problem if the unit is working fine then just snap the buzzer off the curcuit bord
Jul 07, 2010 | GE DBXR463GD Gas Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Have a Whirlpool dryer 6 yrs, last few weeks noticed that the drying cycle took longer, today the dryer goes on, turns, but does not heats up. Can you help me? I'm desperate.
If you have a gas dryer...
If your dryer is electric..
heatman101
Apr 15, 2010 | Whirlpool LER4634J Electric Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
Apr 01, 2010 | LG DLG5932W Gas Dryer
My GE Dryer dries but only after a longer time than before
One of your heating element is probably out of commission. You can replace it cheap. Here's how:
SOME REPAIR PICTURE
Dec 16, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
109 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
