Question about Brother MFC-7820N Printer
Printer displays fail to warm up whenever it is turned on
Error message on display is "fail to warm up". I know it's not the toner. hopefully it can be fixed as it appears to be a nice machine. if not I lost almost $100
Fuser is not coming to ready...sorry, but "yes", you did lose $100
Posted on Jul 17, 2009
How to reset error c2558 in bizhub 215
I have solution for this problem now. I tried alot to sought out this C2558 error in bizhub 215 & 195 but i got failed. But now i have a solution for this error after wasting my 2 days & searching data, youtube, website, manual, installation guide & more. Here is solution for this C2558 Error in Konica Minolta Bizhub 215 & 195 :-
Step-1. You need to change your developer(a packet pouch of developer), if you have not done yet. if you have already changed your developer then jump to step2. (Note - for installing & refilling devloper into the cartridge check other guide on youtube for how to re-fill developer.
Step-2. Be Carful there should be no Toner bottle. Don't get confused with tonner bottle & developer both are different. so remove tonner bottel from machine.
Step-3. switch Off & re - switch on the machine .
Step-4. when machine finish warming after that - Press UTILITY (tool) button. Then Enter service mode by pressing the buttons [Stop], [0] [0], [Stop], [0] [1]. (Note you should press this sequence in continous). The display shows the service mode.On the menu SERVICE WITH chioce press [OK].Use the buttons next to the display and select menu FUNCTION.
Step-5. Press [OK].
Step-6. Use the buttons next to the display and select the menu AUTO ADJUST TCR.
Step-7. Press [OK] and set ATDC. For about 2 min. the following message appears: TCR TCR AUTO ADJUST GAIN: ### where ### is the number
Step-8. Turn the machine off the main switch.
(finished if there is no error message , you can check print without tonner bottel. after that if there is no error message of c2258 then you can put bottle inside)
If the machine displays an error message C2557 or C2558, check whether you have correctly connected terminal, which is detached when removing the developer.
Installing the toner bottle :-
Step-1. Before using the toner Shake the toner bottle.
Step-2. Open the front door.
Step3. Insert the toner bottle into about halfway with the label (Tape) on top of the toner bottle, and then slowly Just remove the label from the toner bottle.
Step-4. Align the toner bottle to mark the arrow and push the bottle to the far end of the toner bottle.
-----GOOD LUCK-----
Aug 13, 2014 | Office Equipment & Supplies
Whenever I switch on to start operating, during my waiting to warm up, it displays error code C-D369. and it doesn't function from there.
Error code reset:turn OFF the copier ,press and hold the Utility key to right hand,to left hand turn ON the copier,wait appaire on the display Trouble reset,touch the screen and turn OFF the copier.Wait 2 minute and turn ON.
Jan 17, 2013 | Konica Minolta bizhub C250 All-In-One...
Error code c2558 for konika bizhub 215
I have solution for this problem now. I tried alot to sought out this C2558 error in bizhub 215 & 195 but i got failed. But now i have a solution for this error after wasting my 2 days & searching data, youtube, website, manual, installation guide & more. Here is solution for this C2558 Error in Konica Minolta Bizhub 215 & 195 :- Step-1. You need to change your developer(a packet pouch of developer), if you have not done yet. if you have already changed your developer then jump to step2. (Note - for installing & refilling devloper into the cartridge check other guide on youtube for how to re-fill developer. Step-2. Be Carful there should be no Toner bottle. Don't get confused with tonner bottle & developer both are different. so remove tonner bottel from machine. Step-3. switch Off & re - switch on the machine . Step-4. when machine finish warming after that - Press UTILITY (tool) button. Then Enter service mode by pressing the buttons [Stop], [0] [0], [Stop], [0] [1]. (Note you should press this sequence in continous). The display shows the service mode.On the menu SERVICE WITH chioce press [OK].Use the buttons next to the display and select menu FUNCTION. Step-5. Press [OK]. Step-6. Use the buttons next to the display and select the menu AUTO ADJUST TCR. Step-7. Press [OK] and set ATDC. For about 2 min. the following message appears: TCR TCR AUTO ADJUST GAIN: ### where ### is the number Step-8. Turn the machine off the main switch. (finished if there is no error message , you can check print without tonner bottel. after that if there is no error message of c2258 then you can put bottle inside) If the machine displays an error message C2557 or C2558, check whether you have correctly connected terminal, which is detached when removing the developer. Installing the toner bottle :- Step-1. Before using the toner Shake the toner bottle. Step-2. Open the front door. Step3. Insert the toner bottle into about halfway with the label (Tape) on top of the toner bottle, and then slowly Just remove the label from the toner bottle. Step-4. Align the toner bottle to mark the arrow and push the bottle to the far end of the toner bottle. -----GOOD LUCK-----
Jan 15, 2013 | Konica Minolta bizhub C450P Laser Printer
Minolta bizhub 164 error code C2558..how can I solve
Step-5. Press [OK].
THATS IT - YOU ARE DONE - FINISHED
DONE - ERROR REMOVED
-----GOOD LUCK-----
Mar 06, 2012 | Office Equipment & Supplies
CLX 2160 Message: Deve Home Sensor Error. What can i do to correct it.
There could be two problems
A minor error occurs and the machine is waiting an error to be cleared. Check the display message, and solve the problem referring to Understanding display messages, see page 11.3.The toner cartridge is low. Order a new toner cartridge; see Ordering supplies on page 12.1. You can temporarily improve print quality by redistributing the toner. See page 10.4.
For referring this page numbers, please download the manual from this link.
http://downloadcenter.samsung.com/content/UM/200812/20081215154056890/Guide_EN.pdf
The error message, which you have told me, not in the error message list. I think there is an internal failure for the printer. It is always recommend servicing your printer with authorized service centers. If the error message is not in the error list, owner cannot repair but, technician can repair the printer. I hope this information is useful for you. Thank you.
Apr 19, 2011 | Samsung CLX-2160N All-In-One Printer
Error message OKIC3200n printer
I called the OKI help number, in the manual, and they told me that the second line of the error message, was just an additional reminder, to replace the magenta toner.
Sep 29, 2009 | OKI C3200n Led Printer
Error message on c.itoh ci3500 printer reads a11. What does it mean?
What is the error message?, not clear on the make and model either, be specific please.
Apr 21, 2009 | Citoh Office Equipment & Supplies
Error message: invalid toner yellow
If the toner is empty it will display this message and the only way I know of getting rid of it is to replace the cartridge. They do make refill kits with extra chips so you can cut the old one out and sticky tape another on. As for a clearing code I am unaware of one for this unit as the information is store in the toner cartridge.
Sorry
Jan 06, 2009 | Samsung CLP-600N Laser Printer
"Warming up Please wait" error
Suspect the toner heating element (fuser) may be malfunctioning. Dell may be able to walk you through a "hard reset" that involves opening the front door, turning on an off the printer with certain buttons held down, etc.
Jan 14, 2008 | Dell 1600n All-In-One Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Brother MFC-7820N Printer Logo
463 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
