Toshiba 50 Class 1080p 120Hz LED Smart HD TV - 50L3400U 50 to 59 in Logo
Posted on Apr 30, 2016
How to reset forgotten pin code using universal remote ? is there a master code?
Dog at original remote
1 Related Answer
gopakumarg43
  • 76851 Answers
  • Posted on Feb 01, 2015
SOURCE: Need to know how to remove pin code or factory reset my tv. No original remote only universe. Toshiba LCD 32" 32SL410U serial # B36533T16403A. Someone locked my tv and I need it unlocked.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
I set parental controls on my Sony OLED TV.
Master Code and Reset
Reset your Sony TV PIN
  1. Press the HOME button.
  2. Scroll down to Settings.
  3. In the Personal section select Parental Lock (Broadcast)
  4. Enter the Master PIN (9999)
  5. Select Change PIN Code and change it to your desired PIN.
Reset your Sony TV PIN - YouView Support
YouView Support https://support.youview.com > parental-controls-and-pin
How do I set a PIN code for my TV or cancel ...
Sony https://www.sony.com > electronics > support > articles
Parental lock · Select System ? Parental controls ? Change PIN. · Select Watching TV ? Parental controls ? PIN Code. · Select Device Preferences ? Parental ...
Forgot my pin code
You mean the security pin?Have you forgotten the Security code for your mobile?What is your mobile model?I suggest you to try default codes like 00000 or 12345.If it does not work out you can use master reset generated code from Unlocking4free.com and reset the mobile.Here they provide master reset for Nokia (Basic) and Alcatel mobile models
Unlocking4Free com Free Mobile Phone Unlocking Tools
Jan 02, 2014 • Cell Phones
Security pin
Nov 22, 2013 • Cell Phones
Our dog ate our remote control. Is there a code we can use to reset with a generic remote, as we need to reset for some channels
Well the reset on your dog probably won't work so it may eat another remote.
On the tv when you use a universal remote you enter a code for the remote. this lets it talk to the tv and should give you the same access to menus ie setup as the original. I don't see a tv model but when you get the universal it will have a list of all the codes. You just look up your manufacturer and then look for your model and enter the code. There may be a few codes per model so you just have to try each one until it works. Unfortunately for some off brand tv's the codes don't work but they are quite good for most. Your other alternative is of course getting a oem replacement.
And even with out a remote you can usually access the menus by pushing the buttons on the front of the tv. Its slow rather frustrating but should work if nothing else.
I have a sharp LC-M3700 monitor I purchased used. It has a Pc code on it and will not let me open the monitor without the code. A yellow icon comes up that looks like a remote control with numbers and...
Page 61 of the manual shows how to bypass the pin if the pin number is forgotten with the remote, however you need the factory remote as a universal won't work. If you knew the pin number a universal remote would work to enter the numbers, but i'm guessing that you don't know the pin number in this case and there is no other way to reset it without having the original remote. These monitors were made for commercial use and have a pin lock to protect the settings in from being tampered with in a commercial installation.
https://www.manualslib.com/manual/151442/Sharp-Lc-M3700.html?page=61#manual
I need a new remote control. My dog chewed up the original. Is there a universal remote I can buy that works with my ilo tv?
Try website like Remotes.com to buy the original remote.Any universal remotes is find,but getting ur tv codes to work on ur tv universal remote are 70/30%,u want to tries with the univeral remote,it up to u.
Remote control switch destroyed
If you get an universal remote, you won't have all functions to control the TV. Moreover, the codes for many audiovox model are often not reported on universal remote manuals , therefore you may need to use autodetect feature on universal remote.
The best choice is buying a replacement original remote like the ones below:
New Original TruTech PLV31199S1 Remote Control
$39.95 -
New Original Trutech PLV31199S1 Remote Control $39.95
2answers
Forgotten pin number
Master pin code is 1668
you can now change pin code by entering prental control using 1668 as old pin code then put in new code
Dog chewed my Philips DVD remote!
Remote codes
http://www.remotecentral.com/index.html
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
