Question about Plantronics Lands Phones
Plantronics t20 not getting power, light green on power source but unit not getting power
Instructions for set up of... plantronics s10 head set and mic to a dsl box and also to use a magic jack.....I only have one phone line and am trying to figure out how this os done???any help would be very...
The S10 amplifier/headset system sets up like the Plantronics S12 system of which the user guide is included in the link below. As you will notice, it is designed to work with a telephone. It will not work as a stand-alone unit. To connect it to a dsl box, magic jack or any other line you will need a phone.
Plantronics S12 User's Guide
Good luck from Headsets Direct!
Oct 10, 2011 | Plantronics (45647-04) for S10, T10, T20...
My plantronics bluetooth headset will not charge when plugged in
It can be one of a few reasons. First, you want to make sure that you have a good power source. If it's not charging, it could be your cord or phone. Normally the AC adapter has a light to indicate it has power. If that's the case and you have a good connection between cord and phone, and your headset still doesn't light up at all after being on the charger, it's time to take it back to your retailer and get it replaced. If they refuse, you can call Plantronics at 800-544-4660 x5 x5538 for warranty assistance.
Sep 19, 2011 | Plantronics Voyager PRO Bluetooth Headset
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
If not on mute with my plantronics t10 headset phone then I heard a loud static hum. What can I do about this?
On this humming, you do not say if this is something new that has just developed or if this has been happening all along. Is this with a different phone than when you started?
First always unplug all the connections and start over making sure that the connections are located in the correct slots. If the humming is still present, the unit may have been damaged in some way. It does have a 1 year warranty. I would check this link for the Plantronics User Guide for the T10 headset that you have.
May 05, 2011 | Plantronics (45647-04) for S10, T10, T20...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
What causes the Plantronic H251 to have static and fades during radio transmissions?
There are too many variables with this question. The S10,T10,T20 are designed to have a specific headset used with them. If you have purchased a cord with a quick disconnect on one end and a phone type plug on the other and then plugged it into the base amplifier using a H251 headset that may be why there is static. I would say that you need to have the original headset or correct replacement for the base.
Oct 26, 2010 | Plantronics (45647-04) for S10, T10, T20...
Plantronics Voyager 500a Bluetooth Headset
Try re-syncing the headset to the base unit:
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8165&p_created=1128461658
Jun 22, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Telephone line RJ11 jack does not fit into plantronics
The correct connection size for headsets used with S10, T10 & T20 is an RJ9. The jack on the back of the T10 and T20 is an RJ9, this is for the cord that runs into the wall jack. The cord itself has an RJ9 on the end that plugs into the T10 & T20 and an RJ11 connection on the other end that plugs into the wall jack. This cord is supplied with the units.
Oct 03, 2009 | Plantronics (45647-04) for S10, T10, T20...
Is it compatible with an IPCC nortel network phone?
I am personally using a Plantronics CS60 wireless headset with a Meridian Nortel M2006 Phone and it works just fine.
Here is how you can setup the Plantronics CS60 wireless headset.
NOTE: Before setting up the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
Jun 02, 2009 | Plantronics CS60 Wireless Headset
Lands Phones Logo
23 people viewed this question
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
