Question about Motorola Cell Phones
Have parrot 3200 LS for car. My microphne stops
Have parrot 3200 LS for car. My microphone stops working when temp heats up. This happened after 4x drive adventure.
Worked fine for a year. I can hear incoming calls on my speaker but no one can hear me. My voice dial does not recognize me.
System works sporadically. Usually 1st thing in morn it's fine.
I've changed cell phones but nogo. Help!
  • matcag Jul 17, 2009
    I'm just looking for a 2nd look to make sure I have all the info before i move on to try another solution.
    thx
    Suggested solutions were helpful. They will allow me to debug this problem further.
  • 3,037 Answers
The side socket on the LCD will work, though you should never need to use it.
Just plug the mic in the socket. If that doesn't work you have a faulty 3200LS (maybe the processor) and you should see if the warranty is still good. If not, then see how much it will cost to send it in, have it looked at, and what it might cost to fix by the company. Otherwise you might just look into getting a new one, these systems occasionally have this problem, so possibly the company may fix it for free for you. Let me know how this turns out for you.
Benjamin
Posted on Jul 17, 2009
  • 4,472 Answers
Unfortunately this sounds like an internal problem. These types of devices are not meant to be serviced by consumers. Have you tried updating it to the latest software? You can do that here http://www.parrot.com/usa/support/downloads
Just download the update tool and that will walk you through the steps. I would also check your phone on the compatibility list. You can also contact parrot technical support here. I would do that once all else fails. As this may be a defective unit. http://www.parrot.com/usa/support/technicalcontacts
Please let me know if you need further assistance.
Thanks,
Lee
Paired my nokia with my 3200 ls kit worked ok but then stoped and now my nokia cant detect my 3200 ls kit
Try deleting all paired devices first, Menu / settings / paired devices. The remove the battery from your mobile phone for ten seconds. Then try pairing again, this should do the trick, if not the parrot may need a software update.
Nov 23, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I have just bought a new apple I phone 4. I can not get it paired to my Parrot 3200 LS. I am "told" the 3200 LS will not work with Iphone 4. The phones "sees" the parrot but on the...
remove all the previous paired phones from the parrot memory and then try again. if this dont work then you will need to have the software of the parrot updated. You can do this yourself but you will need a laptop with bluetooth. then download the software from parrot web site.
Feb 03, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I have a Parrot CK3200 LS-COLOR and when I make a call I can hear the person that I am calling but they cannot hear me! Any suggestions what could be the problem.
First, you will have to check if the microphone does not have a trouble.
Try to make a crossing, you call someone and you move the place of the microphone to get an idea if the trouble is still existing.
check the volume of the microphone into the menu of the kit to ensure via increasing the volume sound.
what combination of products do you have?
please inform cause it helps to find out.
Jan 04, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
How do i pair my blackberry with parrot 3200 ls, asking for numeric key
The first time that you switch on the 3200 LS-Color, you must pair your mobile phone with the kit.
1.Enable the Bluetooth mode on your phone.
2.On the hands-free kit, scroll through the menus until you come to Settings Pair with phone and select the relevant option for your phone. A 4-digit PIN code then appears on screen. Memorize it.
3.Then from mobile serach the 3200 LS-Color device
Once the search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on your phone.
4.Select the kit. Your phone prompts you to enter a code: key in the code shown on the kit screen and confirm on your phone.
5.The kit's screen displays "Pairing".
6.Once the data has been exchanged, "pairing successful" appears on the 3200 LS-Color.
Thank You
Oct 08, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
No one can hear me/sound is very bad Parrot 3200
it sounds like the microphone is trapped or faulty, get the engineer back to sort it out or follow the microphone wire to see if is trapped behind the trim going down the side of the winscreen.
Dan
Feb 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Problem transferring contact list from BB 8330 to Parrot 3200 LS
I had the same issue with my Nokia phone a long time ago. To solve that issue I had to upgrade the Parrot's firmware with the laptop through bluetooth connection while in the car. I have done this a few times to get the most out of my parrot.
I recently got a Blackberry and had no issues with the contacts whatsoever. I do have to say that I dont have 500 contacts, but only 130.
If I were you I would try to update the Parrots firmware to the latest one available in the parrots website.
I am not sure if the parrots has a maximum contacts restriction. That might be also your problem.
Hope it helped.
Nov 26, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot 3200 Ls doesn't cut out radio
problem is the 220 has an amplefier in boot the controls the radio, unless proper leads that connect there are used to interupt the radio when call happens it just some thing u have to put up with or buy the lead, try autoleads.com or look on parrot web site for the right leads
Mar 30, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Cell Phones Logo
66 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
