SOURCE: Portable Navigation Device
go to main menu hit change preferences page 3 show gps status hit configure scroll to other nmea gps receiver and select change baud rate to 4800 hit select hit com7 then go outside for a few moments and hit done.
SOURCE: The navigation software
I Installed my update the day I got it, using Vista. It works fine. My only complaint is the speaker is not loud enough, and the mic is not strong enough for anybody here me on the phone using the bluetooth feature.
SOURCE: hp ipaq hw6915 gps not connecting
down load regedit and make some changes in the register so you will get an ikon GPS make the changes you will find i many forums and it will work
SOURCE: HAVE NAV-CAM 7000 GPS....NEED UPDATED SD CARD W/SOFTWARE
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150362945965&ssPageName=STRK:MESELX:IT
SOURCE: how to install map of
HI.here are the steps:
MAp must have been save to a USB.
First. Tap in the system interface to enter USB Option
Select MASS ACTIVESYNC and tap to save the setting
Second Install the application Mobile Device in a drive of PC. Then the following icon will appear in
the drive selection.
Third. Connect the MINI USB terminal of the USB cable to the MINI USB port of the GPS navigator
and the standard USB terminal to the USB Host port of PC.
Fourth. After the PC finds new hardware, double click the Mobile Device drive in the selection area toenter the memory of GPS navigator for data transmission.
Fifth.After transmission, unplug the USB cable.
Attention: For data safety back up the navigator data.
NOTE: If MASS STORAGE is selected while the GPS navigator is connected with PC, other
operations will be suspended.
ATTENTION: The following operations will stop suspend the communication of the system and PC
and unsaved data will be lost.
1. Unplugging the MINI USB cable;
2. Powering off the GPS navigator;
3. Resetting the system;
4. Tap the on close button on the top right.
