Question about GE (PSS26MSRSS) Side by Side Refrigerator
My Crosley side-by-side frig/freezer has hot spots on the outside. The outside of the freezer is hot as is the wall between the freezer/frig. But everything on the inside is fine. What does that mean?
  • GE Master
  • 1,606 Answers
Either the fan which cools the compressor is bad or the coils under the refrig are dirty .
Posted on Jul 17, 2009
Freezer not working, fridge is fine.
That seem to me like it could bea simple cleaning. Dust and junk gets into the condenser. Blow that ****** out and party on. I have your models service manual on my foggy blog
Mar 05, 2012 | GE GSS25LGM Side by Side Refrigerator
The freezer is freezing up behind the panel causing the frig side to become hot
check with dealer or company regarding frig in back panel.side always become hot due to inbuilt condenser.place in such a way that front and both the side facing to open area.do not face to wall either of the side.back panel towards the wall will do
Nov 17, 2010 | GE Refrigerators
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Side of frig is hot
Make sure the condenser fan underneath the unit where the compressor is is running. If that's not it check for ice buildup behind the back wall inside the freezer .(defrost problem)
Jul 12, 2009 | LG Refrigerators
GE GSS20IEPAWW Freezer Not cold outside of freezer very HOT
check to make sure that the fan in the back is working and then clean the condenser coil underneith the frig
Apr 26, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Outside wall on freezer side is hot to the touch
clean your condenser coils under the frig,your over working with dirty coils and it is over heating-mike
Oct 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Something is burning on the freezer side of samsung side by side freezer
it is normal to the fridge to be hot of the side edge panel it is to prevent moisture around gasket. cluster pipe of condeser routed around instead to install elec. heater. its to hot from the start of applying power but once it reach lower temp it will be warmed and normal.
Jan 11, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
347 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
