Question about Toshiba Satellite M55-S3512 Notebook
Do I need to use recovery disks or is their an easier solution?
On a black screen I am getting the following message:
"The system could not be restarted from its previous location due to a read failure. Delete restoration data and proceed to system boot menu."
I can't get past this screen and don't know how to undertake these steps. I can't find an answer on the Toshiba website. Help! and thanks.
  • 1,006 Answers
Re: Do I need to use recovery disks or is their an easier...
It can be problem with HDD or ram
Virus infected
Try this metode:
Go start run type MSCONFIG start up and desable ALL PROGRAM but just dont desable ANTIVIRUS!
Let me know if u got help
Posted on Nov 18, 2007
  • 98 Answers
This error occurs on notebooks occasionally after returning from hibernation, the sleep mode in WinXP. There's no option for returning to the Desktop, so you may lose your work. Use the option to Delete Restoration Data And Proceed To System Boot Menu, which will cause WinXP to reboot.
0 characters
3 Points
I have an HP Compaq tc4400 that I got from an old friend that had no use of it . but when I turn it on it says Non-system disk or disk error replace and strike any key when ready but I dont have a disk ....
It sounds like there's a problem with Windows (assume that's the operating system it used to have). I think you'll need to get a Windows install disk. Installing Windows is actually not that hard, and it sounds like you've got nothing to lose.
If you don't have access to a copy of Windows, why not try out Windows 8 -
I assume it'll only be free for a few more days as Windows 8 will be released in under a week now.
Hope that helps.
Oct 21, 2012 | PC Laptops
Need To Reboot to factory settings
System Recovery is Factory Settings. Did you make the System Recovery Disk or are you trying to use the Recovery Partition that the manufacturer put on your hard drive?
Anyway, for the time being lets forget about system Recovery since you say it does not work.
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 26, 2012 | Acer PC Laptops
How do i reboot my laptop fujitsu siemans alimo pro without disks? does this restore all hardwear & softwear?
First a rebot is just shuting down all running programs the starting them back up, Reboot is the same as Restart. You perform this by clicking Start then Restart. The second part of your question about Restoring is called System Restore And that is done differently depending on your Operating System. In Windows 7 just click Start then type System Restore then hit enter and System Restore will start and you can follow the steps from there.
In Windows XP click Start then click Run then in the Run Box type msconfig and hit Enter yoir System Configuration Utility should then popup and you just click on LAUNCH SYSTEM RESTORE near the bottom of the window. You should then be able to follow the directions.
System Recovery is sometime another option, Which you may or may not be able to do.You can perform a System Recovery on many computers. This will return your hard drive to the ORIGINAL factory configuration, with everything it originally had. First, find out if your computer supports this option
Go to My Computer, and look under Hard Disk Drives. A lot of PC's today will include two hard disk partitions. There is always a C:\ drive (normally the Windows drive) and often a D:\ drive. The D:\ drive may be called "Recovery" or something like it.
If there is no D:\ drive, you may have to do System Recovery from a disk. Contact your PC manufacturer to order the disks. It's easier than buying a new PC.
WARNING! SYSTEM RECOVERY DELETES ALL FILES YOU HAVE CREATED AND PROGRAMS YOU HAVE INSTALLED. It restores the hard drive to its original state, This means that all files you have created are DELETED! Including Installed Programs! You MUST backup anything you want to keep! Backup utilities are installed with every version of windows.
Now to perform System Recovery. Restart your PC. As Windows is loading, look for a message that says "Press [KEY] for System Recovery". When you see this message, press the given key and follow the instructions, sometime they flash so quickly you cannot hit the key in time if this happens just restart and since you know which key this time be ready and hit it when it flashes, hopefully you will be able to perform a successful System Recovery.
In Windows 7 you can Start system Recovery the same way you did System Restore just type Recovery instead of Restore
If you do not see this message, but see other messages, try pressing them. Example: "Press [KEY] for Startup Options".
Jun 08, 2011 | PC Laptops
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
Need a reboot disk for compaq presario 1278 series cm2070 model 1456VQLIN does not have an OS
Most Compaq's come with what is known as "reimaging" or the OS already installed on a partitioned part of your harddrive (which is locked) unless you go in and have your computer do a System Recovery to factory settings...
Know that if this is your only option, then you will loose everything you have on your computer up until you got the error message...
Ok, first things first..
What were you doing before you got this error?
Are you able to boot to your start up screen and get to System Restore? If not and all else is lost, then follow the following instructions
1. Restart the computer "Press key, it's up above your 0 for recovery" message is displayed
on the screen. Then select Recovery Manager. Then your Recovery Manager will come up
2. Choose Advanced Options.
3. Choose System recovery, and then click Next. It will instruct you to reset your computer to Factory Settings...all you need to do is follow the Recovery Manager Wizard options and click next and next and so on... let me know if this works....
Dec 02, 2010 | Compaq PC Laptops
Wont boot up,black screen.message on screen says,invalid partitio
When you power up your computer, the system examines the master partition table to determine what volume to use to boot up the operating system, and detected invalid information within it. This is caused by an incorrect or missing active partition.
To resolve this issue, consider the following steps:
  • Boot up the computer with a Microsoft Windows 98 boot up disk or Windows XP recovery console. Select the correct bootup device before you do that.
  • At the DOS command prompt, type in: fdisk
  • Question - Do you wish to enlarge large disk support (Y/N) ?
  • Enter: Y
  • Now to check for active partition, enter: 2
  • Look under the Status column. The active partition is usually assigned to the drive which contains your operating system.
  • If there's no active partition set, enter the number of the partition to make active
This must solve your problem.
Apr 15, 2010 | HP Compaq Presario 2200 Notebook
No operating system
Contact Acer and have them send you a new recovery disk. Be sure to have your computers paperwork handy when you talk to them. The problem" operating system could not be found" could be software or hardware related. I'd try to load the OS using the recovery disk first and see if that fixes the problem... mpawlak
Oct 06, 2009 | Acer Aspire 9300 Notebook
Black Screen Error, Windows Vista Dosenot Boot
You have a complicated issue that is very difficult to repair using this one way conversation method. I must, however, compliment the detail of your description.
From what I can see, you have a problem with one of two, or possibly two of two things. One message says your network card is not functioning properly, the other says your hard drive is not functioning properly.
Either of these issues may be either the device which has failed or the software which controls it has failed.
If you have access to another machine, you may be able to remove the hard drive and test it (this would be my first choice, since a recovery disk should still work even if the Network card does not).
By testing the harddrive, you can be sure it is working properly. If it is working properly, the next test would be on the memory. Believe it or not, memory often will stop a system from reading data off the DVD drive during recovery or installation of the operating system.
This one would be much easier for me to help you diagnose if I had it in my possession, and I'm certain most techs will tell you the same thing.
Additionally, the recovery disk may actually be bad, and this can be investigated with a visual inspection. Look for scratches and fingerprints on the disk.
And often, Windows Vista does not install unless the BIOS is set to the INSTALL OS mode. Different machines do this differently; and again, if you had another machine that was working, it would help.
Good luck.
May 17, 2009 | Toshiba Satellite L355-S7817 Notebook
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Start up problem
This generally indicates a hard drive failure. You can try to do an operating system repair with the recovery or operating system disc, but most likely you will need to replace the hard drive.
When you see the IBM screen you need to enter the boot menu. On this screen it tells you what to press to get to the boot menu. Place the recovery or operating system disc in the drive, and select the CD drive from the boot menu, then follow the directions. If the repair doesn't work, then reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced. You want to do a full NTFS format, not the quick format, if the hard drive is bad, it won't format.
Aug 08, 2008 | IBM ThinkPad T30 2366 Notebook
Toshiba Satellite M55-S3512 Notebook Logo
217 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
