Question about Mtd Arnold Corp No. Mtr - 42 - Ec 42" Mwr Blade Set
Alright i have a riding mower yardman and i poured some gas down under the air intake cover down some black hole right next to the air filter..now it wont start and nuthin will turn.just a click.
    Sergeant:
  • 199 Answers
The black hole is a crankcase vacume tube not a big deal there but i would check the battery connections and the battery. if you use gas directly in the carb to start it doesent take more than a tea spoon to do it you will flood the engine and drain you battery just trying to start it.
Posted on Jul 17, 2009
Riding lawn mower will not start. Craftsman Model 917.28851. New battery, new fuel filter, spark plug is newer, cleaned air filter.
Pour a little gas into the carb intake where the air filter fits on.If it starts but then stops it is a fuel problem and most likely will need a carb cleaning/repair.This is a common problem because of ethanol in the gas.ALWAYS when a mower sits for a extended period run the carb dry of gas and do the same for all small motor equipment.
Apr 13, 2018 | Cars & Trucks
Sat unused for 3years,new battery,oil change spark plug,air filter,started right up,battery some how died after trying to restart within 15 min.any ideas what might be happening
once the motor starts it would only draw from the battery for electric deck clutch if you have one or headlights if you have any. There will be a black wire coming out from under the flywheel, in that wire there will be a bumb half again bigger then wire only about 3/4 inch long, it is a diode covered with heat shrink , this allows for the electricity to come out of the charging system into the battery but not back the other way. So if the diode has gone bad and allowing the current to go both directions this might be your problem. charge your battery, start your mower, you will need a cheap ohm meter $10, with the tractor running full throttle touch the red test lead to positive + and black to neg, meter set at dc current it should read 13 to 15 volts when engine is shut off it should be 12+ volt if it is under that say 11 volt you have a draw some where,
Feb 28, 2016 | Yard Man Yardman Riding Lawn Mower 38in...
How could gas be entering the crankcase of my Husqvarna 48" riding lawn mower?
Sounds like you have a hole 'burnt' in the piston top allowing fuel combustion mixture (normally compressed above the piston) getting down into the crankase or that the piston rings are shot allowing the same thing.
As the piston is continuously moving, the reverse happens giving oil at the intake or carb.
. Looks like a strip down, good inspection and rebuild of engine required .
Sep 20, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My Yardman 13.5 hp Briggs rider revs up and sputters, revs up and sputters.
Does this engine have overhead valves. If yes they need to be checked for proper valve clearance. The engine must be cold to check this.
Sep 24, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Need to fix yardman lawn mower, gas is pouring out the primer hole..
you need to remove the air filter assem first the you will see the carb
May 13, 2012 | Garden
After changing a blade on my viking mower, it no longer starts, is there oil in the air filter? how do i fix this ? Thanks
It sounds like you tilted the mower in the wrong directions when changing the blade. If you tilt it with the spark plug pointing down insead of up, this alows the oil in the crankcase to enter the head and then it bleeds past the intake valve and or exhaust valve where oil then gets in the carb./ air filter or muffler. Pull the spark plug out and inspect, it may be covered with oil killing the fire. Check your oil level, replace your air filter, try to start. It may smoke real bad for awhile. It should clear up after getting hot and burning it out of the muffler.
Dec 04, 2010 | Garden
I have water leaking on the passenger floor board when it rains and I can't find were it's coming from.
Check the seal around your interior air filter. The seal can come off at one corner and allow water to run down the firewall and into the passenger side.
Apr 02, 2010 | 2002 Chevrolet Impala
Floods while mowing-remove air filter -gas running out air intake.
First, go outside and stand next to the lawn mower. Then as hard as you can kick it. Keep kicking it until you feel better. Now go down to your local Sears and tell them that you need a new lawn mower and watch all of those guys scramble to make the sale.
Happy Shopping.
Aug 09, 2009 | Garden
1997 yardman lawn tractor with 14.5 b&s won't run if i pour fuel in carb it will start but dies as soon as the gas runs out.
does it have a fuel filter? if it does clean it, if not look at the fuel line it might be cloged from gas sitting too long
Jul 11, 2009 | Mtd Arnold Oem - 190 - 784 2 Wheel Weights...
Mtd Arnold Corp No. Mtr - 42 - Ec 42"  Mwr Blade Set Logo
99 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
