Question about Kenmore Dryers
Doesnt heat up
The heating element never starts and it doesn't heat up in my Kenmore dryer
    Genius:
  • 1,122 Answers
Remove the back panel and check the heater box fuse and the heating element-mike
Posted on Jul 17, 2009
Kenmore dryer 11062062100
If a dryer is not heating - and it is electric, then the first thing to check are the breakers. It runs on a double breaker and half of the breaker may be good (allowing for other functions other than heat). Half breaker will run motor and timer but the element needs both breakers (220v). If that is not the issue, then element may need to be inspected.
Apr 11, 2014 | Dryers
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
My dryer kenmore elite 11074972300 doesn't heat
I had this problem with one of my dryers and it turned out that the heating element was broken. It is a repair man that you need now I'm afraid.
Nov 04, 2012 | Dryers
Dryer doesnt heat
Its your heating element most likley . could be heat sensor high or low . I would replace the element .
Jan 29, 2012 | Kenmore Dryers
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
We have a Kenmore Gas dryer it runs but it doesnt get hot.. any ideas what it could be?
The heating element is most likely burned out. Try ordering a new heating element for your dryer and calling a repairman to put the new heating element in.
Jul 15, 2009 | Kenmore Dryers
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Dec 19, 2008 | Kenmore Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
