Question about Flat Panel Televisions
Specks on LCD TV
The TV has speckles from the mid upper left to the bottom and about 10 inches across. It is only real apparent when the tv is showing a dark picture or dark colors.
  • 77 Answers
SOURCE: blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Posted on Jun 25, 2007
  • 31 Answers
SOURCE: Dark lines appearing across my lcd tv
This is symptom of LCD Faulty. Please note down cost of LCD is much high. In my suggestion
you change or purchase new TV
Posted on Nov 12, 2008
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
  • 934 Answers
SOURCE: I have a samsung 52 inch lcd tv and it takes about
T-con or timing control board is defective or the syscon link board that feeds the panel itself... For that problem you'll need to take it to a shop - the whole Tv has to come apart to get to the T-con so it can be properly tested...
Good Luck!
William Rayburn, CET
Premium Technologies
Posted on Oct 05, 2009
  • 1961 Answers
SOURCE: one day old samsung 40LC530 LCD tv shows a dark patched screen
that is a factory defect you call the dealer for the warranty.the defective part of your tv is the inverter board.this board supplies high voltage supply to the backlight cold cathode flourescent lamp.This lamp is the one illuminating the screen of the tv..the lamp is installed at the top and bottom of the screen thats why the center of the tv is dark because the lamp does not lit well..tnx
hope i help you
please rate my help..
Posted on Jun 05, 2010
SOURCE: 42" LCD tv shows picture on only half of the screen,other half dark!
The T-Con board (otherwise known as LVDS) connects to two seperste parts of the LCD panel. If you do have half a picture (left or right) replacing the T-Con board should resolve this issue. Open your TV, find the part number and search on eBay or at sites like where you can search by TV model number.
Posted on Oct 07, 2011
0 characters
1 Points
Samsung TV thick black line running across the bottom.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 08, 2016 | Samsung PN51E450 - 51" Class 50.73...
Plasma Tv Turning black in areas and speckles red and green as it gets hot.
plz check if the internal cooling fan are in good working condition. avoid keeping magnetic, very nearby.
hope this helps
Thanks for using Fixya
Jul 12, 2008 | LG MU-50PZ90C Television
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Flat Panel Televisions
Sounds like a Tab Issue,Connections are Become Bad on the Inner Connections to the Screen,The Real Fix would be to Replace The Panel
Dec 30, 2011 | JVC LT-37X688 37 in. LCD HDTV
Toshiba 40 inch tv with picture edges gone.
Are you using a cable box or a satellite receiver? They too have format, Zoom, or view mode buttons.. It seems like there's several names for them but they do the same thing. I hope this helps.
Mar 04, 2010 | Toshiba 40RV525U 40 in. LCD TV
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Flat Panel Televisions
Maxent MX-42XM11 Plasma HDTV
finding correct tv code for mexent 42 inch plasma tv for direct tv receiver
Dec 31, 2007 | Maxent MX-42XM11 Television
Blue Streak
I had the same problem w/ the same TV about 6 months ago. You need a new optical engine. Hopefully you are still under warranty. Once that was replaced, the tv looks great.
Dec 26, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue snowy pixel areas on my plasma
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Large Black Strip across the bottom of the (TV Cable) Picture
This happened to me too and i fixed mine by going into settings and for some reason my subtitles were turned on. turn it off and it should fix it.
Jan 14, 2007 | Hyundai ImageQuest HQL320WR 32 in....
Flat Panel Televisions Logo
70 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
