you need to scan some of the bar codes found on the manual.
Find the product reference manual -usually found on the cd with the scanner or download from motorola site - and in chapter "symbologies" scan "ENABLE CODE128" barcode.
To have prefix when a code is scanned, scan "SCAN OPTIONS" then " then "ENTER"
Last set the preffix value by scanning "SCAN PREFFIX" then four digits that correspond to the character you want to use as preffix.
If you need more than one character for preffix then you will need the Advanced formatting manual, which ican be downloaded from motorola. In this case you need to create a "rule".
Attached are the programming barcodes for the LS2208 solve this problem. Print the attached file and scan the barcodes in order 1-10. This will only work on a LS2208. If you scan the Set Defaults barcode it will erase this programming rule.
there is a document you will need to scan to do this, if you want to send me an e-mail i will send you the document
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
