Question about LG Televison & Video
How to find audio fix on my LG flat screen tv to finish connecting my wireless head phones
    Master:
  • LG Master
  • 708 Answers
Hdmi splitter and hdmi switcher are different,i bought a hdmi splitter and it works perfect,see details: Amazon com MALLCROWN 3D 1080P 4 Pport Hdmi Splitter with ac power adapter...
Posted on Nov 21, 2016
    New Friend:
  • 26 Answers
Well Hi Maria ! Let's get you fixed up.
I want to help you with your question, but I need more information. Maria, with my wireless headphones, I have 2 types:
a)Has 2 "RCA Type" connector plugs, you can identify them simply as one is red(My memory trick is R is 'RED & R for right side, and a white one, for the left side) do you see these plug type connectors that attach to the broadcasting unit that sends the signals to your wireless headphones, so they can go without wires?
b) Or...do you have a broadcasting unit that has 2 different types of plugs, 1 is still a red "RCA type", and the other is a different type, a "BLACK" Plug type ?(It is called a 3.5mm Plug)
If you have "type a)" 1 x Red RCA &
1 x White RCA, then all you need to do is to look at your HDTV manual, an find where the "AV OUT" plugs are, make sure it is the OUT, (Caution: It won't work if there is "NO" audio from some source hooked up to at least one the HDTV's in sources, it could be AV, or HDMI, whatever you chose to use.
Carefully move the HDTV, so you can safely get behind it and locate the AV OUT (Female type) plugs at the back, remember "R" is for RED PLUG & always "RIGHT" Side, and "WHITE" PLUG is for the "LEFT" Side. Hopefully the cords are long enough to get out from behind the HDTV, andto a place where their signal can reach the headphones. If not, I get very inexpensive RCA cables, & other things at "My local DOLLAR STORE, for about $3.00" And you should be set. Remember, Start your headphones with reset, and slowly search until your audio matched the video on the HDTV.
If you have the "type b)" you have 2 options. If you plug just the "RED RCA plug into the back of the HDTV, IMPORTANT** You will ONLY get (Remember "R" red for Right hand side) you only get Right Had Sound (REALLY, who wants that, with all the nice stuff you bought ??)
Soooo... That "BLACK 3.5mm Plug means you have "2" choices
a) Unlikely Choice- If there is a 3.5mm audio OUT Female Plug receiver that accepts the Black plug, then THAT's IT. The Black plug. is like most microphones, headphones, etc, IT HAS BOTH THE LEFT & THE RIGHT SIDE SOUND SIGNALS> Again, if it's not long enough, , go buy an inexpensive extension plug (Factory Direct Store sells a 25 foot extension cable ***FOR ONLY $6.99 ****-
- I love that place !! )
b) if like most HDTVs you have the same 2 RCA type AV out Female Plugs, you will need to buy what is called a
"3.5mm (Female)to RED & White RCA PLUG SPLITTER" -
and guess where you get them reaaly cheap ??
See above !!.
When you have your RCA to 3.5mm Splitter Cable (Hey it's late & I don't remember the right name, I think this is the one !!), plug The "R" for RED to the "Right" side AV RCA plug for AV OUT, & the "White" plug" to the "Left Side" AV out plug,& the 3.5mm Black Plug (female) will plug into the Cordless Headphones Broadcaster's (Male) 3.5mm Black Plug, move the Broadcaster out front so your Headphones can pick up the signal
LAST !!!
2 things
#1- Always try to be sure that you could draw an imaginary "LINE OF SIGHT" between the Broadcaster Unit, and where you will be wearing the headphones for the best quality of signal (You want to enjoy it now, right !)
#2- BE VERY VERY CAREFU, PATIENT, when you move the HDTV back or foorward. They are EXPENSIVE !! AND !!! IMPORTANT, !! They are a LOT HEAVIER THAN THEY LOOK< AND COULD REALLY HURT YOU,if they fall on you, or you will not feel so smart if after all this, your nice, expensive HDTV, is BROKEN, OK?
PLEASE BE CAREFUL FOLKS !!!
Posted on Apr 29, 2016
5 Suggested Answers
SOURCE:
  • 11 Answers
SOURCE: VCr connection
should be a source button so kind on the remote or on the tv
Posted on Nov 24, 2007
skotkolr
  • 558 Answers
SOURCE: hooking my flat screen tv to my home theater
Since your output is coaxial (rca) you should be able to find an input for coaxial that will work on your surround the setting on your surround will be either coaxial or digital input,
hope this helps
it would help if you said what kind and model of surround you have
Posted on Dec 09, 2008
  • 814 Answers
SOURCE: new proscan 32 lcd tv. Won't work with sony wireless headphone
Try using the PROSCAN website customer support, to find the answer to you questions.www.oncorpus.com. You will need some type of adaptor from th coax output to the input of you system. For the wireless problem you may need two adapators one from the tv to you receivers and a sound output to wireless adapator. You can call them at their customer support telephone number 1-888-977-6722. I hope this information helps you with your problems.
Posted on May 21, 2009
  • 171 Answers
SOURCE: connect external pc speakers to flat screen tv
get a 3.5mm -> rca adapter. You need to convert from the 3.5mm jack that your speakers uses to the rca jacks that your tv expects.
Like this:
http://ecx.images-amazon.com/images/I/31TelR%2BsCYL._SS400_.jpg
Posted on Aug 31, 2009
I have a samsung flat screen TV with a3.5 mm audio out jack when plugged in to dvd player audio in rca jacks no right channel plug head phones into tv have l and r channel.
The audio jacks on the DVD player get connected to the audio IN RCA jacks on the TV The audio out jack on the TV is for a sound bar or amplified speakers.
Nov 24, 2015 | Samsung Televison & Video
My LG TV 50LS4000 has a blue screen and audio and no picture. How can I fix it
Blue screen is an indication of missing video signal input. Check all of your input video connections for any loose or broken wire/connectors.
Nov 26, 2014 | LG Televison & Video
HOW TO CONNECT HEAD PHONES TO TV
is it a wireless headphone or a wired one..??
genrally wired headphone use 3.5 mm audio jack ... try to find the 3.5 mm jack input on your tv and connect the headphone..
Sep 09, 2013 | Televison & Video
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
How do you get the tv to connect with the wireless internet router?
The manual is here if you need it:
http://www.lg.com/us/tv-audio-video/televisions/LG-47LC7DF.jsp
After perusing the manual, it looks like the TV may not have a network capability...
wired or wireless
Jun 09, 2011 | LG 47LC7DF 47 in. LCD HDTV
I have an lg 32ld350. I plugged in headphones into it as to not annoy anyone with the tv and when i was done i unplugged them and now i have no sound unless i use headphones. Even with them unplugged it...
Turn off ur tv.Tries take the head phone steal jack plug it in and unplug it out do this like three or four times.Tries the tv menu audio resetting again.The audio should return.Don't used ur tv head phone again the input jack socket it have problems,just lower ur tv volume for not to annoy anyone.Or used the tv head phone jack socket again will damage it for good, and will never get sound out throught ur tv speaker again.
Apr 16, 2011 | LG 42PX5D 42 in. Plasma HDTV
Lg 42LH30 tv trying to connect a Sennheiser w/l RS120 wireless headset and I do not see an audio out connection on the back of the tv I looked up the specs of the tv and the only audio out I see is...
This is an optical digital audio output that uses optical fiber with Toslink optical connectors at both ends, from there it comes the name, since your wireless headset has only analog audio input, you'll need an optical digital audio to analog audio converter, to connect your wireless headset to your TV.
Mar 18, 2011 | LG 42LG30 42 in. LCD HDTV
I have an LG 42PG6010. Can I use head phones with this TV as it doesnt have a head phone port
if the tv has audio outputs you can send the audio to an amplifier (such as surround sound amp or ect) then plug your earphones into the jack on the amplifier. another option is to purchase wireless headphones which have a built in amplifier and the base only needs to be connected ot the tv's audio out.
Mar 11, 2011 | Televison & Video
Just bought an open box LG LED 42 inch TV. I got a couple questions. 1. What is the recommended way of cleaning the screen? 2. How do I get it to recognize my wifi? 3. Please provide me a link to an...
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
http://www.lg.com/us/tv-audio-video/televisions/LG-led-tv-42LE5400.jsp
From the manual, here's what it says about cleaning:
thomascha103_1.jpg And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
thomascha103_2.jpg That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
Best of luck!
Jan 12, 2011 | LG 42LE5400 42 in. LCD TV
Can i hook up a headphone to my emerson flat screen tv
yeah you can, from audio out, you can connect your head phone but after plugin an adopter of audio jacks which convert the audio out jacks to headphone pin.
good luck, feel free for more information
do rate if helped
Dec 04, 2010 | Emerson LC320EM8 32 in. LCD TV
Televison & Video Logo
57 people viewed this question
RONALD CARTER JR
