Question about Bissell 1960-3 QuickSteamer Plus Upright Vacuum
Missing key part for proper function
I hope you can help!! I love this little steamer, it has worked amazingly well until my 13 year old got a hold of it to clean a spill. Apparently he was trying to figure out how to put the water in the fill tank and removed the lid and washer from the base of the fill tank (the little washer with hose is still there). He became flustered in not being able to figure it out and thinks he tossed it!! If at all possible, how do I go about getting a replacement part?
  • 48 Answers
Get in contact with bissell on thier web site,
They have a spares center,
Posted on Nov 18, 2007
Replacement
Probably. If it's not very old, try taking it back where you bought it. If it's still under warranty, claim warranty from the manufacturer.
Aug 03, 2014 | Euro-Pro Shark SC710L Handheld Steam...
Why is vax s7-a+steam mop steamer dripping water and cuts on and off
I managed to fix mine after a little effort. It was blocked well up in the nozzle into a small pinhole where the steam comes out of the 'small kettle' in the steam mop.
To fix:
  • take the blue side bit off by unscrewing the two small screws
  • Undo the screws inside (there are about 11)
  • Once these were undone there was two screws holding the nozzle cover.
  • After unscrewing these pull the nozzle cover of and scrape limescale from inside the small hole where the steam comes out
  • Put it all back together and it should work much better
You should only really do this if you are competent as there are lots of wires etc. and if your steam mop is not covered under warranty as messing around with it will void this.
Hope this helps :)
Jul 04, 2014 | VAX Appliances Vacuums
What is the difference between the 2 eureka enviro steamers: the 310 model, and the 313A? are they doing the same job, and which one is a better buy i.e., does the job, and does not cost an arm and a leg...
Greetings,
The Eureka 310 Envirosteamer is no longer made. Eureka discontinued this particular model several years ago. It was a very highly rated steam mop at the time, so Eureka came out with a new model that had a very upgrades which was the Eureka 312, which is also now discontinued. These two old models are discontinued because Eureka has introduced the 313A which is the best model they've made to date. This is the most current, and only upright steam mop that Eureka makes currently, so if you are going to buy a Eureka, the 313A is the one that you want to buy. It's a great steamer I think. We do offer a 60 day full money back guarantee with any purchase, I hope you will consider us when you're ready to go for it.
Please feel free to request a clarification here on Fixya if you have any questions I can answer further for you.
I hope this was helpful information for you. If this was helpful, please rate it as helpful by clicking on the thumbs up icon in the lower right hand corner.
Thank you so much,
Chris J.
Mar 17, 2010 | Eureka Enviro Steamer 310 Stick Vacuum
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
sounds like you have the plastic bodied canister. the controll valve inside is bad. I usually just disconnect those to avoid future problems. you may want to take the vacuum to a repair shop though becuase they are a pain to get apart and get back in one piece.
Jul 15, 2009 | Electrolux Vacuums
How to put automix piston back in place of a Bissell Power Steame
Called the Bissell Power Steamer customer service number and the CSR explained how to turn the water control knob counterclockwise 260 degrees until the automix piston grabbed hold. Worked like a charm. Thank you Bissell company.
Jun 18, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Can't get the top unscrewed
I had the same problem. Mine had been stored for a year. We had to completely destroy the plastic cap. Once down to the metal underneath we did the boiling water thing. It didn't work at first so we tried it again. And then immediately after applying the boiling water we used ice water to make the metal contract. With pliers on the neck and pliers on the lid we were able to open it. But, I know my husband had to put some strength into it. Hope this helps you all!!!
sorcha1580
Nov 16, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Spotbot is leaking...
Mine constantly leaked as well but I found that if I remove the container will the solution in it after every use it doesn't leak anymore. I store my container (upright - nozzle face up) under the sink with my other cleaning products and when I need to use the machine I pull it back out, pop it in and clean.
HTH
Dec 28, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell 1960-3 QuickSteamer Plus Upright Vacuum Logo
70 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
