Question about Creative Labs ZEN Vision:M Digital Media Player
I need to reformat my Zen. How - Creative Labs ZEN Vision:M Digital Media Player
  • 1,511 Answers
To format a Creative Zen is quite simple. Turn off you player. Then hold the play button and turn on your player. You will now see a menu that gives you options to format. After, select the option to reboot/ restart. There are other options to clean up and reload firmware also.
Thanx and i hope this helps
Please rate this solution
Posted on Jul 17, 2009
If there is a small hole on the bottom of your Zen, then this is a simple matter. All you need to do is just turn off your Zen, use a needle, pin, or something small that will fit inside of it, and hold it there pressing the button in as you turn it on and it will send you to a 'safe mode' menu giving you multiple options, Clean Up, Format All (which would be the one that you would choose), Reload Firmware, and Reboot.
Posted on Jul 31, 2009
Stuck on the logo zen neeon 2
remove music and reformat then put music again
Jun 23, 2009 | Creative Labs Zen Neeon MP3 Player
Need ot reformat a zen. How do I do it
george,
Connect your ZEN to a PC, once the PC detect your player a new removable device will be add to "My computer" either drive . point the newly found device and right click mouse button into it. a dialogue bix will appear indicating selecetions, choose "Format" then left click mouse button,
cheers,
mark
Jan 31, 2009 | Creative Labs Zen Digital Media Player
My player doesnot play but it just shows the word [CREATIVE] why?
The funny thing was that I could see the drive in My Computer but I couldnt access the directory because it was apparently corrupted
So I reformatted the player using comand prompt. So far, I uploaded one song and I was able to turn the stupid zen stone on and play it.
WARNING: Reformatting the drive will delete ALL files in the player.
Hope it works for you!
Jan 29, 2009 | Creative Labs Zen Stone Plus MP3 Player
Player wont open; is reformat possible?
you have to get a toothpick and then stick it where it says restart.
then it should work =]
Oct 06, 2008 | Creative Labs Zen Digital Media Player
Zen
If the computer's reformatted you (might) have to reinstall the zen. Go to "control panel" >> "add hardware" and try add it again
Jul 21, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen - can't download music from XP SP2
When you plug the Mp3 player into 2 computers running slightly different versions of XP, a reformatting occurs which will cause it not to work on one PC or the other. You must reformat your player for the home computer. Actually, you might want to check the firmware also: Go to Creative's website and double-check the firmware - it will also give you the best way to reformat your player:
http://support.creative.com/Products/Products.aspx?catid=213&catName=MP3+Players
Jul 06, 2008 | Creative Labs Zen Digital Media Player
Creative Labs Nomand Jukebox Zen Xtra
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved.
Oct 31, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
ZEN NOT DOCKING TO COMPUTER
if you are using a fromt usb port- switch to the back usb. The front ports don't always give the zen enough power. Also- look in Device Manager and see if there is a zen listed there- and if it is does it have a yellow exclamation mark? It may not be the zen that is having problems but your computer.
Oct 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen Microphoto frozen..
Solution ID # 4794 from creative site ZEN Micro and ZEN MicroPhoto 1. Make sure that the battery is charged. 2. Detach the ZEN Micro or MicroPhoto from the PC, and ensure that it is turned off. 3. Remove the battery. 4. Move and hold the Power button to the Power On position and re-insert the battery to the ZEN Micro or MicroPhoto. Hold the Power button until the Recovery Mode appears. The following options will be displayed: -Clean Up : Scans the player and removes invalid links from its music library.Does not affect music files themselves. -Format (All):Caution! Erases all content!Save a copy of your player's content before formatting. -Reload OS/ Firmware : Caution! Erases your player's firmware. DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install. Reboot Reboots the device.
Jul 29, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Creative Zen Nano Plus FROZEN!!!
here is a fix if your creative zen nano plus just hang on the creative logo when you turn your player on.
download, Creative ZEN Nano Plus firmware.
you can find it at the creative website, download section.
double click the file you just dl'ed, now make sure your
zen nano player is already connected to your pc when you run the file. it may take a bit of time before your pc can detect your zen nano be patient, a window prompt will soon appear asking if you want to update your firmware with the one youve just dl'ed.
now, dont worry if the firmware is the same as the one already
installed in your zen nano, just continue with the update.
you can also check the box in which there is the option of also formatting the drive. ( note: all files in your zen nano will be lost)
after the firmware is flashed you can now play and transfer files to your zen nano plus.
May 01, 2007 | Creative Labs Zen Nano Plus MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
787 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
