Question about Volkswagen Golf V Vw Scale Diecast Model
What is the maximum size of wheel that i can put on a Golf 97 CL
Wishing to know what is the max sixe of tire i can put on this golf 97 CL , 1.8L , It currently has 14 inch rims ... THANKS :)
  • 43 Answers
In theory, you could go up to a 17" rim with an ultra-low profile tire. The stud configuration on the Golf, however, makes it hard to find the larger rims, and the ultra low profile tires are very expensive. Your best bet is to take it in to a tire shop to find out what can be ordered for the vehicle. If you wanted to order sets online, make sure you measure the distance between the studs and the depth of the wheel.
Posted on Jul 17, 2009
Tyre size for VW golf GTI 2003
it should be on a sticker on the inside of your door jamb
Feb 09, 2010 | 2002 Volkswagen Golf
Does the vw golf 1994 cl diesal 1.9 model have
they sold em both ways with or without! just look donw the front of the motor see if theres a power steering pump on it
Jan 22, 2010 | 1994 Volkswagen Golf
2003 GOLF GTI THE BEST TIRE SIZE FOR 17'' RIMS???
I would advise you to leave both sides with 235 45 17 this tire size would provide you with better handling and improved comfort also tires wil be more protected of suffering damage in the sidewalls caused by bumps and potholes just remember to keep them inflated at 38 +/- 2 psi.
Jan 13, 2010 | 2003 Volkswagen Golf
My 1995 VW Golf 3 VR6 engine refuse raise to the maximum when reved.
Thats because the car ecu is program to do that if you want to bypass that , you will need to buy a computer chip and install it ..it will let the car rev to red and give you max speed i belive its max is 160 mph.
Oct 16, 2009 | 1995 Volkswagen Golf
Change of wheels and tyres on VW Golf
Well, as someone (in my younger days!) who put tires of sizes not recommended by the car manufacturer, I feel bad discouraging your son from the 'awesome' tires/wheels he wants on his VW. It is generally recommended that tire size (diameter) not vary by more than 3%. If I did my math correctly, there is a difference in the sizes (diameter) you state of 5 %. Go to 'tire rack' website for formula and info to verify my rusty math skills! The speedometer would be off, due to the larger diameter wheels, resulting in a speed indicated that would be too low (less revolutions per mile). So, besides risking a speeding ticket due to lower speed indicated on speedometer, My main concern, would be that our modern day computer controlled engines base their readings on engine and auto speed, and it will be working with false speedometer readings.
Apr 08, 2009 | 2004 Volkswagen Jetta
Need chrome rims. What size do I need ? Thanks
There should be a sticker on the door near the latch with tire sizes recommended for that vehicle. last # is wheel size (14, 15, etc) This is also the size on the tire itself (205-75-15 is a 15" wheel) Then all you need is to match the bolt pattern. Any wheel retailer knows correct size or buy from someone who has same vehicle. Don't exceed recommended tire sizes unless you intend to also change speedometer to match the new final drive ratio.
Mar 31, 2009 | 1986 Mitsubishi Mighty Max
How mush air i need to put in my golf gti 2.0 year 2000
well that depends on how much air the tire requires if the tire requires 32 psi you will need at least that much to fill your tire and so on
Mar 24, 2009 | Air Tools & Compressors
Tyre Pressures for Golf Estate 1.6 ?
Hi philipoevans, what size of tires do you have? need to know this in order to tell you what pressure they need to be good luck
Nov 11, 2008 | 2002 Volkswagen Golf
1997 vw golf
u need an air compressor ( prefferably) an air gun or really good ratchet, a VERY long extension for ur ratchet/ air gun and a torx bit. Cant remember which size bit it is by heart.
Need an air gun to remove the wheel lug nuts, and then the center bolt from the axle. (think its 32mm)
Then with ur torx bit, remove the 6 bolts around the axle, they are about 4 inches from the tranny.
The extension for ur ratchet needs to be about 30 inches long.
Good luck.
Jun 13, 2008 | 1997 Volkswagen Golf
ABS Light
posible the bad tire broke the abs sensor or wires, look inside the tire meaning inside under the car and see if any cables goin to tire are broken and have it repair
Jun 04, 2008 | 2003 Volkswagen Golf
Volkswagen Golf V Vw Scale Diecast Model Logo
199 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Kulu Criss
Kulu Criss
Bogdan Odwazny
Bogdan Odwazny
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
