Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
My motorcycle won't completely drain
I took off the drain plug that my manual instructed me to take off. Only about .5 pint came out. There is at least 4 quarts in it and I know that for sure. I have a 2007 suzuki boulevard c90t. What do I have to do to make it drain completely?
  • 116 Answers
Take off the filler cap while you drain it needs vent or it vaporlocks
Posted on Dec 30, 2009
How do you turn on the 30 pint KU34313 dehumidifier
I think you have to put water in it then push the start switch. The manual has a complete set of instructions.
Feb 21, 2014 | KUL 30 Pint Dehumidifier
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
Looking for information on 1988 honda vlx radiator
Instructions
    • 1 Remove the motorcycle's carburetor and clean it with carburetor cleaner, getting rid of any and all grime and deposits within. If necessary, use an air compressor with a small tip to blow out any clogged lines within the carburetor.
    • 2 Check the motorcycle's fuel tank for old fuel. Drain the fuel tank completely and refill the tank with fresh fuel. Old gasoline isn't good for most motors, especially older ones.
    • 3 Remove the motorcycle's seat by unscrewing the two mounting bolts on both sides of the back of the seat with a 12 mm socket wrench. Pop off the top of the air box and remove the bike's air filter. Clean this thoroughly in hot, soapy water. Rinse it off, let it air-dry then apply air filter oil before reinstalling it in the motorcycle.
    • 4 Check the tire pressure and integrity of both tires on the motorcycle. If either tire is flat, leaking air or overly worn, replace the tire and tube.
    • 5 Change the motorcycle's oil. Warm the bike up, then remove the oil drain plug underneath the transmission and drain the oil. While the drain plug is still loose, fill the oil reservoir until oil begins to run out of the plug. This means the reservoir is full. Tighten the drain plug.
Jan 20, 2013 | Honda VT 600 C Shadow Motorcycles
Instructions on how to use holts wondarwald
Holts Wondarweld
Flush engine.
EXTERNAL CRACKS
1 Run engine until hot,drain off enough coolant to remove thermostat.
2 Remove thermostat.
3 Mix contents of can thoughoughly! and pour contents into thermostat opening.
4 Replace thermostat cover.& fill radiator with hot water,replace radiator cap.
5 Run engine at a fast idle for 15 mins,dont allow to boil.Top up if necessary.
6 Leave Wondarweld in system for 2-3 days then drain off,flush system replace thermostat and refill.
HAIRLINE CRACKS
1 MIX thoroughly and pour into cold engine (radiator if it has a cap)
2 Run engine until hot.
3 Allow engine to cool then run again until hot.
4 Follow procedure 6 above.
INTERNAL CRACKS
1 Follow external crack instructions except after pouring Wondarweld into engine remove spark plug from
affected cylinder and run engine for 20 mins. If more than one cylinder affected run for 5 minute intervals.
2 Allow engine to cool then drain cooling system and refill with clean water.
3 Drain sump & flush,refill with fresh oil.
Note:- 1/2 pint of Wondarweld for every 6 pints of water,DO NOT add antifreeze for at least 3 days after process.
Aug 05, 2012 | Cars & Trucks
Soleusair 45 pint dehumidifier won't drain through hose
We have a Soleus Air 30 pint that initially would not drain through the hose that we attached and dropped down the sump drain. After reading here, I tried tilting it back about a quarter inch and that didn't fix the problem. Then I tilted it forward a quarter inch (I put a couple pieces of cardboard under the back wheels) and it started draining properly. It is doing a marvelous job of dehumidifying the house now!
Mar 04, 2012 | Dehumidifiers
My qlink Siena 150 got excessive oil build up in the air box from not draining. Oil got in carberator now won't start. I have cleaned every thing out completely and it still won't start even...
Drain the carb if you haven't already, be sure the gas valve is on and the plug wire is attached, check for a kill switch in the wrong position, then give the air intake a shot of spray starter fluid. Hopefully that will get you going again.
Jun 08, 2011 | 2008 Qlink Siena 150
What type of Dana is in the rear of the 98 4cyl wrangler
Engine, with filter..........6.1 quarts [1]
Cooling System, Initial Fill..........10.6 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 30RH Initial Fill..........4.1 quarts
Automatic Transmission, 32RH Initial Fill..........4.1 quarts
3 speed 30RH..........7 quarts
3 speed 32RH..........8.6 quarts
Manual Transmission, AX-5 2WD..........7.4 pints
Manual Transmission, AX-15 2WD..........6.8 pints
Manual Transmission, AX-15 4WD..........6.8 pints
Differential, 181 FBI Front..........2.6 pints [2]
Differential, With 194 RBI Rear..........3.6 pints
Differential, With 216 RBI Rear..........4.1 pints
Transfer Case, 242..........3 pints
Transfer Case, 247..........3.4 pints
Transfer Case, 249..........3.4 pints
Transfer Case, 231..........2.2 pints
Feb 14, 2011 | 1998 Jeep Wrangler
What is the fluid capacity of the gear oil in a 1997 nissan 5 speed 2 wd truck
CAPACITIES
Engine, 2WDwithout filter..........3.5 quarts[1]
Engine, 4WDwithout filter..........4.0 quarts[1]
Cooling System, Initial Fill..........8.5 quarts
Automatic Transmission, Total Fill..........7.4 quarts
Manual Transmission, 2WD..........4.2 pints
Manual Transmission, 4WD..........8.4 pints
Differential, 2WD Rear..........3.2 pints
Differential, 4WD Rear..........2.7 pints
Differential, Front..........2.7 pints
Transfer Case,..........4.6 pints
TORQUES
Oil Drain Plug.....22-29 ft-lbs
Transfer case
Fill Plug.....18-25 ft-lbs
Drain Plug.....18-25 ft-lbs
Manual Transmission
Oct 17, 2010 | 1997 Nissan Pickup
What kind of ATF goes in my 1992 cherokee?
Use ATF+4
Do not use Dexron or Mercon
Aug 08, 2009 | 1992 Jeep Cherokee Sport
Where's the fill plug on 5 speed manual transmission 93 mustang 2.3
It will be on the passenger side of the tranny about half way up.
The bottom plug is the drain plug and the top one is the fill plug.
You will fill it to the bottom of the fill plug,it will hold around 5.6 pints.
Mar 23, 2009 | 1993 Ford Mustang
Lands Phones Logo
48 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
