Question about Pentax K100D Digital Camera
The camera is saying "memory card full" or "image not stored". Of course we have taken all photos off card so it isn't full, and also have tried 2 other memory cards , but to no avail! Not sure what else to do.
  • clhayman Jul 18, 2009
    thanks, will try that now.
    We unlocked it and now it say s "the image is not stored" yet there's definitely space>?
    We reset again and it's now working, thank you!
    Problem Solver:
  • 14 Answers
Hi have you tried to reformat the memory card in the camera. Sometimes if you reformat it in the computer the camera does not like it. Also make sure your camera uses either an SD card or a SDHC card. Also make sure the lock on the side of memory card is off. Lastly get a rubber and try cleaning terminals where memory card meets the camera do camera as well as memory card. If all this fails go to website and look for any updates, you may be able to update firmware. Hope one of these work. Best Regards ALex
Posted on Aug 07, 2009
It says "memory full". I have a 512 mb memory card and have only taken 48 pictures.
It could be full especially if the images are stored at a very high resolution.
Mar 09, 2013 | Cameras
When I turn on my Vivitar DVR 410,it says:Memory Full! Please insert an SD Memory Card.Then when I insert my card, it still says Memory Full! Please insert an SD Memory Card.It wont let me take a...
Remove the SD memory card from the camera, go into menu and locate "format" follow the prompt to remove all photo's from the internal memory, when completed install the SD card back in the camera to resume normal operation.
May 28, 2011 | Cameras
It keeps saying memory card is full. Bought a new memory card and put in and it still says the card is full.
Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal memory card is full" there is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the picture size setting you have selected on your camera. Keep in mind that the camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Hope helps.
Apr 28, 2011 | Kodak EasyShare One Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
Feb 22, 2010 | Pentax Optio S5z Digital Camera
Changing memory settings
the camera allows for 8 pics to be taken using its internal memory (IN). If you want to be able to get more images than that you can purchase an xD picture card that gets inserted to the camera that will allow for more images to be taken and stored. The camera more than likely supports 1gb or 2gb capacities of xD cards.
May 27, 2009 | Olympus X-875 Digital Camera
Can't take photo's
There should be 2 settings, 1 for internal memory, 1 for external (card) memory. Internal memory is always low, especially if camera is set to high quality photos so only a few can be taken. check your settings on picture quality.
Jan 04, 2008 | Fuji FinePix S8000fd Digital Camera
MEMORY CARD
I had the same problem today with a 2 GB card. I think it may be the size of the card. When I put in an old 32 MB card it worked fine.
Dec 26, 2007 | Vivitar ViviCam 3785 Digital Camera
Memory Card Full
Hi, 1.make sure your memory card is not damaged and also formatted by camera ,this is because if card is damaged or not recognized the camera stores image in internal memory which may be full by this time. 2.backup all your data and delete all from internal memory also format the card and try using it. All the best my friend regards sreejith
Jul 17, 2007 | Pentax Optio E30 Digital Camera
Pentax K100D Digital Camera Logo
183 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
