Re: How do I do a touch screen calibration on this...
Hi . you can do the calibration from service mode but is useless. better disassembly the control panel. remove the touch screen and clean all surface with a alcohol dampered cloth
The touch screen could have lost its calibration, but there is a good chance that it is bad, and needs to be replaced. To calibrate it, push the yellow clear modes key, then the numbers 1, 9, 9, 3, then push the red "Clear / Stop" key 5 times, and choose number one. Follow the prompts. Use a stylus or other dull pointed item. If you don't get a response, you need a new touch screen.
Which model of Ricoh are we talking about here? If touch screen is not responding before replacement, re-calibrate touch screen or replace it. I can help you with the calibration code if you require. If the touch screen is not responding after replacement, check whether the replacement lcd display panel was installed reverse as the connectors will not have contact.
Press the keys listed below, please note you need to press the Clear/Stop key 5 times. The screen will change after entering the keys and touch screen calibration will be option number 1. The calibration will consist of pressing a couple of small circles on the screen.
Clear Modes->1-9-9-3->Clear/Stop(5 times)
or
Reset->1-9-9-3->Stop(5 times)
Hello!
Try calibrate the touch panel to see if it work.
- Press yellow key
- On the key pad press 1993.
- Press 5 times red key (stay pressing a bit longer on the fifth time)
Then you will see an option to calibrate your touch screen. You will need to press the point.
If this doent work you will need to change the touch panel.
Press and hold down energy saver button and function button together then power on the machine. keep on holding the two buttons the machine will once show screen calibration marker then again show the calibration markers now touch the shown marker it will go to a new place keep on touching the final marker will be at center of screen . after touching it the calibration completes
You need to calibrate the touch screen.
Try this:
Press Yellow key
On the key pad Press 1-9-9-3.
Press 5 times the red key (the 5th old a little longer)
(If everything is good in the touch screen shows an option "calibrate touch screen")
Try to touch there and will show a little arrow on each corner. With a pen click there to calibrate the touch screen.
Click exit and its done
Press the yellow clear modes button then press
1 9 9 3 and the red clear/stop botton 5 times
this will open up the touch screen calibration menu
select calibrate touch screen. follow on screen directions.
Good Luck
