Question about Mastercool 67471 Evaporative Cooler Air Conditioner
We bought at a yard sale a Bonaire cooling system, product # 6250020, ser. # 00133551, it leaks after awhile and also sprays water out the front, i have sent another one of these but forgot to put product # and ser. # down Thanks Diana
2 Suggested Answers
  • 30 Answers
SOURCE: we bought a Bonaire cooling system at yard sale,
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Posted on Jul 18, 2009
How to check vacuum leak to hvac
use a spray bottle filled with water
spray a mist of water over the area where you suspect a leak while the vehicle is idling
if there is a vacuum leak the idle speed will rise and drop
Aug 17, 2016 | 2006 Pontiac G6
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
Vacuum leak
An old trick to finding Vacuum leaks is to use a spray bottle of water and mist seams and vacuum solenoids while the engine is running. Check the Brake booster too!
A broken EGR diaphragm can leak air into your system.
Apr 13, 2013 | 2004 Ford Escape XLT
I have a evaporative cooler WF-818 portable that I bought at a yard sale. Where is the removable water tank and how do you fill it up with water?
From the picture i saw of it i suspect that it is in the front of the unit. The front cover should pop off and the water tank should be in there. Most of these you just pullout fill up and stick it back in. Hope this helps
Jun 04, 2010 | Fujitsu Siemens Celsius R610 PC Desktop
Antifreeze leak near water pump I think Located on side of engine by serpentine belt and altenator
if your water pump has never been changed its a good bet that it is leaking. they are designed with a weep-hole that leaks to warn you that the bearing is going out. You can also verify if the bearing in the water pump is bad by grasping it at any two opposite sides and try and see if you can move it... even a little slight play indicates that it is going bad. if not the pump leaking the cleanup the engine, being careful not to spray water onto your alternator.. then get the car to normal operating temp and look for awhile at all hoses even the ones that go to the a/c heater system. another quick check is to look for crusty deposit buildups on any hoses or lines and then get the car hot and monitor. When i had a leak, it was from a small heater hose and it was a misty spray, i only found it when the engine was running.After you've corrected the problem and the engine is cool take radiator cap off and fill with 50/50 mix antifreeze. Also if you're going to change the pump out i would also change out the thermostat and replace the radiator cap if it looks a rusty and corroded. Can you rate this,,,,thanks!
Apr 29, 2010 | 2000 Oldsmobile Intrigue
I bought a Dazey crockpot at a yard sale. Do you
NO! water where it might end up in the heating element and the base section should not ever be submerged for cleaning, only the removable crockery.
Oct 24, 2009 | Kitchen Appliances - Others
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
Need security code for lg shine cu720 bought it at yard sale
Wow, I wish I could find cool yard sales like that. The factory LG code is 0000, unless the previous owner reset it to something else. If you can find that out no problem, if not, only your cellular service provider can reset the code for you.
Jul 08, 2009 | LG Shine CU720 Cellular Phone
Cooling issues
yup, sounds like a blown heater core and the water is most probably because it`s been leaking for quite awhile now and obviously water is alot cheaper than antifreeze, so previous owner filled up coolant system with water. Normaly a good indication of blown heater core is a sweet smell in the car when u turn on the heat (prestone vapors) and leaves a white and greasy residue on bottom of windshield in the car (right near the dashboard).
Remedy this as soon as u can because antifreeze also acts as a lubricant for ur entire cooling system. System will end up rusting and you`ll eventually scrap water pump. Frozen water (ice) takes expansion as it solidifies, so if water in the engine freezes, it will expand and could crack any hose, engine block or engine head.
good luck.
Nov 20, 2008 | 1996 Volkswagen Jetta
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
224 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
