Question about HP Compaq d530 PC Desktop
There are two lights right under the turn-on bottom and one has a picture of a battery and the other is a picture of a light bulb and this light bulb is blinking red five times in about 3second intervals.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
The blinking bulb is the speed or the utility of the ram memory ....if it is blinking then it means that ur pc is utilising memory of ram....if it blinks faster then its using more memory....
Posted on Jul 17, 2009
How do you change the light bulb under the microwave?
put the bulb of microwave down . and then install a new bulb on it .before do these .you should turn off the switch .
home light bulbs
May 02, 2012 | GE JVM1650 1000 Watts Microwave Oven
Rear lights don't work. brake lights work. right brake light keeps blowing out
88 thru 1991 tail lights leaked like crazy on Camry, check the socket to be sure its not corroded , if so, disconnect the battery and clean them with a small wire brush, or roll up a piece of sandpaper and use that, be careful not to hit the bulb connections at the bottom of the socket ,, what you have is a grounding problem and this should fix the problem cheap and fast... make sure you have the right bulbs, I had a guy try and use a 1156 bulb rather than a 1157, make sure the bulb has 2 connections at the bottom not just one, if it has just one this is a backup light bulb
Apr 11, 2011 | 1988 Toyota Camry
How to change a tail light bulb in a honda element
Open the hatch and the tailgate.
Remove the two mounting screws with a Phillips-head screwdriver, and remove the taillight assembly from the body by pulling it back.
Determine which of the three bulbs is burned out: brake/taillight, turn signal light or backup light. (I assume you’ve already determined this)
Remove the socket by turning it one-quarter turn counterclockwise.
Pull the bulb straight out of its socket.
Push the new bulb straight into the socket until it bottoms.
Reinstall the socket into the light assembly by turning it clockwise until it locks.
Test the lights to make sure the new bulb is working.
When reinstalling the taillight assembly, first place the two pins in the holes in place. Tighten the two mounting bolts.
Hope this is helpful to you.
Jan 10, 2010 | 2003 Honda Element
Bluish color right coener
I'm afraid, it is problem of optics unit block (light engine), there are 3 LCDs red-green-blue for color picture formation and blue LCD sounds bad, please call local TV tech for fix.
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
1998 Lincoln Town Car: No turn signals, 4 way flash, brake lights
If only your brake light in middle of rear window works then your other bulbs are bad. If brake lights all work in the back than bulbs are good. If you put turn signal on right or left and the bulbs light in front and back then you need to change multifunction light control box under dash. My understanding is it cost $600 new. So I would try used.
Jun 06, 2009 | 1995 Lincoln Town Car
How to change head lights of hyundai 1.3i
OK> you may or may not want to disconnect the battery and take it out to give yourself more room. Once you have done this a time or two you will find that you can do it without taking the battery out. When you open up the hood and you are facing the car looking into the engine compartment (we will start with the battery side first). Where the headlights are on the front of the car, under the hood is where the bulb is located. You will see an electrical connector going into a black rubber cover. Peel the black rubber cover back and disconnect the electrical connector. Place the rubber cover to the side and on the inside you will see a very unusual looking paper clip contraption that holds the headlight bulb in place. The secret to this is that it is under tension and held in place in a slot at the bottom. All you need to do is press down, and move it sideways a little bit and it will pop out of the slot. When the paper clip contraption has come out of the slot at the bottom, simply lift it up, and the bulb will come right out. Put the new bulb in, slide the end of the paper clip contraption back into the slot in the bottom, place the black rubber cover back over the headlight area making sure the the (3) prongs from the light bulb are sticking out of the middle of the rubber cover, Re-connect the electrical connector, do the other side the same way and when you are done test the lights to ensure that they both work properly.
Feb 19, 2009 | 2001 Hyundai Accent
1994 BMW540i Break Light Out indicator reset
If the brake light works, disconnect battery negative with ignition key ON and Radio ON, but engine OFF, four minutes after connect Battery terminal, do not panic if terminal sparks wile connecting, *** it well turn ignition key OFF, than start the motor and verify
if problem remains
Jan 22, 2009 | 1994 BMW 5 Series
MONITOR LIGHT STAYS BLUE, BUT NO PICTURE
Hi
If your picture wasn't pinkish or dark at the top or bottom when it was working, then it may be the inverter has gone bad. Inverters are like light bulbs and have life expectancies on the capacitors.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
To get to the inverter:
Remove the stand.
Take the screws out of the bottom rear edge (these hold the front trim)
The the trim then unsnaps. {Be aware of the wire to the power button board on the bottom corner}
Start at the bottom and release the trim by lifting away from the glass of the screen from the center outwards to the corners, then work your way up each side bottom to top (a pocket knife or thin putty knife will help release the catches) These sides can be really tough to pop off especially the last top clip on each side.
Then unsnap the top edge (rocking it while lifting helps)
Disconnect the power button plug or unsrew the screws.
Once trim is off, remove the 4 corner screws that hold the screen in. Then the screen will lift up.
unplug the bulbs and wire to the screen (screen plug that goes into the metal case pulls out)
then the inverter is under the center area under the metal cover
Shout if you need more info.
If you email me a good picture of the inverter , I may be able to get a better idea if it is the inverter from a visual.
Fran
bammbamm@ptd.net
Dec 13, 2008 | Gateway FPD1975W 19" LCD Monitor
Right front turn signal and side lights won't turn on when van turns to the right. Right rear light works but flashes faster than normal. Message center on dashboard also flashes faster than normal the...
Are you sure you have a good ground at those bulbs ? Spray sockets good with cleaner or penetrating fluid, (WD-40 or similar) clean contacts at bottom and try to squeeze or pry outside of socket inward to help get better contact with side of bulbs and see if that helps. If 12 Volt test light confirms power to contact in socket, then I'd be looking for a bad ground. Careful not to touch side while checking contact at bottom of socket or you'll blow a fuse real quick.
Oct 25, 2008 | 1996 Dodge Caravan
HP Compaq d530 PC Desktop Logo
323 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
