Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fisher Paykel Dishwasher Door Open error code
The top drawer on my Fisher Paykel dishwasher keeps giving the error code that the door is open when I try to start it. Is there a switch somewhere that is easily accessible that can be adjusted. or should I call a repair man?
  • gracho Dec 30, 2007
    Thanks Ray_6. But I could not see the clip or fingers. Do you mean at the top of the drawer or underneath at the bottom? I see the arm that holds the cables by looking underneath the drawer. Can the drawer be completely removed?
If it is a dish drawer type there is a clip at the rear of the drawer that holds the drawer closed. you will need to withdraw the drawer partially to look in. with the drawer open the fingers should be facing towards you. If not you will need to reach in and pull the top of the fingers towards the front. there is a replacement arm that holds the pipes and cables away from this part.
Posted on Nov 24, 2007
Fisher and Paykel dishwasher Two drawers. Took top drawer out to fix leaking problem When put back together, closed the door and it is seized shut.
These use a claw type catch that rotates on a fixed loop catch receiver. Try removing the dishwasher lid, and remove the catch receiver to allow the door to open, With care you can then free the catch, and it will need to be adjusted correctly to prevent over rotation again. In the worst case, you may need to remove the inner door panel to free the door catch / receiver.
Feb 02, 2018 | Fisher and Paykel Dishwashers
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Botton door sticking hard to open and close
It is likely the drawer seal assembly is not working properly.
You will have to get the drfawer out from the housing and check the top inside of the housing to see if the seal is broken or can be more complex if the seal actuator motors are out of alignment. Will need to call technician if you are not familar with electrical components.
If you keep operating like this then water leak can cause damage to dishwasher.
Jul 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
DD603 Does Seal need replacement? F1 Error Code
F1 error code appears because moisture has been detected by the flood switch on the base of the housing under the drawer.
If you think the door seal was not fitting properly then that too can cause moisture leak into base of the unit where the flood switch is located. Steam condensation would also lead to moisture.
Best option might be to replace the door seal for the top drawer. This is not a trivial thing as the unit has motor actuated door seal which can be tricky to fit back in.
Also avoid foaming in the detergent by using the correct powder and not tablets.
Please rate this solution if you are satisfied otherwise post a comment.
May 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Gives me a water faucet with a slash. What do I
Apr 25, 2010 | Fisher and Paykel 23 in. DD603H SS...
Fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher and Paykel dishwasher will not keep running.
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the door is open or closed. Wipe these areas with a clean dry cloth...Give it a try
May 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher Draw will not open after Washing
Turn off at wall, DW resets, and you can open drawer. Tell wife not to stuff so much in next time.
Apr 11, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
297 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
