Question about Insignia IS-DVD1001 DVD Recorder/VCR
  • 4 more comments
  • Anonymous Jan 16, 2008
    any body have a solution for this - insignia told me i had to bring it back to where i bought it.
  • Anonymous Jan 23, 2008
  • razorray Jan 24, 2008
    i cant get progressive scan mode off
  • jobel38 Mar 12, 2009
    My progressive scan in on all the time. How can I turn it off.
  • kajaigh Mar 16, 2009
    stuck in progressive scan mode
The person who said menu/down 7x,then R once , then up once and enter ROCKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ty:)
Posted on Jun 22, 2008
Thank you for the solution. I would have never come up with it!!!!
Your a master of the progessive scan mode.
Posted on Dec 24, 2008
Again the person who solved this problem is totally awesome!!!
Posted on Jul 13, 2008
Try pressing menu
then down seven times
right once
up once
and enter
Posted on Nov 26, 2007
3 Suggested Answers
SOURCE: my xbv410 is stuck on progressive scan mode. I
press the set up button on the remote...the word "set up" should appear on the unit. then press and hold the stop button for 5 seconds...problem solved.
Posted on Sep 29, 2010
SOURCE: Locked into progressive scan AND Setup is Unavailable
This solution will also work for GoldStar DVR1000! make sure no DVD or tapes are in the player press and hold stop button and it releases you from Progressive scan mode. After searching the web for hours for this model got desperate and was trying fixes for other brands and models, this one worked. Thanks koolanit
Posted on Aug 19, 2007
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
CAN'T GET PROGRESSIVE SCAN MODE OFF SCREEN, WHAT'S THE FIX? I have a Zenith DVD/VCR player and cannot get the Progressive Scan mode off. Someone please help.
I removed the disk, turned on the devise, made sure it was in DVD mode and held down the stop button for 30 seconds. It finally went away and my old DVD screen came back. Yee Hah!
Jan 14, 2009 | Televison & Video
My sanyo dwm-3900 is on progressive scan mode how do i fix this
If your DVD players is set to Progressive Scan Mode, tehn ther would be a light indicating it is so. The light is labeled P?scan on the bottom right side of your display window.
You can disable/turn OFF the P/Scan mode in the "Setup menu".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
DVD/VCR stuck in Progressive scan mode
With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS. Our DVD was stuck on Progressive Scan Mode for over 1 year, this fixed it. I had tried the press stop, press stop and hold while playing a movie, but not while there was no disk. Try it & Good Luck!!!!!!!!
Nov 02, 2006 | Zenith XBV442 DVD Player/VCR
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 17, 2005 | Zenith XBV443 DVD Player/VCR
Insignia IS-DVD1001 DVD Recorder/VCR Logo
511 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
