RLA= Rated load amps or running loads amps depending on mfg.
FLA= Full load amps
LRA= Locked rotor amps.
watts is voltage times current, So use 220 time the LRA get that watts or 220 times FLA to get that watts and
multiply 220 times RLA to get watts.
most power supplies have a switch for 120 and or 220 options just move the switch to what setting you want. most power supplies can be used as a stand a lone power supply, if not than you need to request for a 220 watt power supply the can be used as a stand alone for pc or computer use. most computer retail should have them in stock. look on line or at www.fryselectronics.com/computer/parts/power_supple/stand-a-lone/for_PC_use/220_watts/
type power supplies stand-a-lone 220 watts computers compatible
Your calculations is correct - 220 X 0.7 = 154 watts. If your fridge only runs on 220 volts then you need solar panels that charge 12 volt lead acid batteries and then use a inverter to convert 12 volts DC to 220 volts AC.
You would have to buy a new ac adapter then for the N64 console JJgames and lukie games ship to Pakistan then. Voltage current for Pakistan is 220 volts.
Black & DeckerMX77PowerPro® 220Watts Hand MixerBlack & DeckerMX77PowerPro® 220Watts Hand Mixer - User Rating: 4 stars. ... There are no signs of rusting around the metal parts. Overall ...epinions.com/review/pr-Black_Decker_MX77_Mixer/...
