Question about Nintendo New Super Mario Bros. for DS
World 3 tower, can't get up red blocks!
In world 3 tower, after I push the button, i can't get up the red blocks fast enough, I've tried like 100 times! What is the sequence, or is there a secret? Once, after I tried it with mega mushroom, I was able to make some of the blocks stay red after bumping them from underneath (after I turned back to normal size), but only the first row. It didn't help, just thought I'd add that though.
    Filmmaker:
    Uploaded 5 video answers.
  • 10 Answers
You can check this video out for an easy walkthrough to this level as well as get all 3 stars :)
Posted on Aug 09, 2009
    Problem Solver:
  • 12 Answers
I'll get back to you after i find the switch you are talkin about
Posted on Aug 08, 2009
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
World Tech Saturn-X - spins, rudder trim doesn't help
I know what the problem is, i had the same issue right out of the box. if you take the cover off the front you will find the battery. on the bottom of the battery is a 2-sided sticky tape to hold it in place, on that tape the is probably a pulled wire. theres red blue black and white (as well as a thicker red and black that lead to the battery. find the wire that is pulled and solder it to the correct part. for me it was the white cable which controlled the top blades. the helicopter spins because both set of blades should counter rotate and if one of the motors isnt getting power from pulled cable the helicopter will spin and flip. Hope this helped. email me at thedew312@gmail.com if you need more help finding where the wires connect
Dec 28, 2012 | Worldtech Devices World Tech 85618 2CH...
Need a new stricker you can't spin the stricker handle fast enough to make a spark
I assume this refrigerator is an absorbtion type of refrigerator, also known as a 3 way fridge ( 12volt, 240 voly and lpg gas.)
The stiker is a piezio crystal which does not wear out. The problem is that the where the spark jumps across the gap has become dirty or blocked in some way.
In general the push button should be easy to push in, if it has become harder to push in that is a sign of dirty "points"
Mar 25, 2011 | Refrigerators
I had my oil changed in October after the "oil
Try this procedure and let me know if this does not work;
Turn the ignition switch to the "On" position but do not start the engine.
1. Press the Trip/Reset button until "Setup Menu Hold Reset" is displayed.
2. Then press and hold down the Trip/Reset button for approximately 2 seconds until "Reset For System Check" is displayed then release the Trip/Reset button.
3. Then immediately press and hold down the Trip/Reset button again for approximately 2 more seconds until "OIL 100% RESET IF NEW" is displayed then release the Trip/Reset button.
4. Then immediately press the Trip/Reset button once to display "HOLD RESET IF NEW OIL" then release the Trip/Reset button.
5. Then immediately press and hold the Trip/Reset button again for approximately 2 seconds until "OIL LIFE SET TO 100%" is displayed.
Turn off the ignition switch, and then start the engine to verify that the reset procedure did work, and you might have to repeat the procedure if the Trip/Reset button is not pushed fast enough, or it is not held down long enough, or it is held down too long during the reset procedure, and it may take a few attempts to be successful.
Nov 11, 2010 | 2006 Ford Explorer
I had the oil changed but the change oil light is still on, how do i reset the computer? 2000 oldsmobile alero
How to Reset the Change Oil Light
After changing the engine oil, the system must be reset.
With the ignition key to ON, push the RESET button
located in the driver's side instrument panel fuse block. The
CHANGE OIL light will start to flash, press and hold the
RESET button again. The reset is complete when you hear
the chimes sound and the CHANGE OIL light goes out.
Oct 25, 2010 | 2000 Oldsmobile Alero
Where does the Microphone plug in to the Dell Vostro200
Depending on the chassis-style of your Vostro 200 (Slim-line or Tower), you may have one or more options for installing a microphone.
See below for instructions:
A. Slim-Line Model
There are two locations on this model (by default).
Front: You have the power button, then 2 x USB ports, 1 x Headphone jack-out, and 1 x Microphone jack-in.
Rear: There is a block of six audio connectors, looking only at the bottom 3 (red, green & blue).
Red = Microphone jack-in Green = Speaker/Audio jack-out Blue = Audio jack-in
B. Tower Model
There is one location on this model (by default):
Aug 15, 2010 | Dell Vostro 200 PC Desktop
Can't get the last coin in world 8 castle the small one after 8-4
WHat you do is do not hit the 1st red button, then hit the second red button and then dont hit any more red buttons
Jan 15, 2010 | Nintendo New Super Mario Bros. for DS
Trigonometric word problem with solution
If the distance of a person from a tower is 100 m and the angle subtended by the top of the tower with the ground is 30o, what is the height of the tower in meters? Solution:
  • AB = distance of the man from the tower = 100 m
  • BC = height of the tower = h (to be calculated)
  • The trigonometric function that uses AB and BC is tan A , where A = 30o.
So tan 30o = BC / AB = h / 100 Therefore height of the tower h = 100 tan 30o = (100) 1/√3 = 57.74 m.
Jan 09, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Warp in world 3 ghost house
It's one of the hardest things to do in the whole game in my opinion... there's not really any trick to it, you just need to keep practicing. I must have tried about 50 times before I made it! ;) there's always somewhere you can shave a fraction of a second off. Sorry I can't help more than this.
Feb 25, 2009 | Nintendo New Super Mario Bros. for DS
Contrast 100 window keeps appearing on screen
try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Nintendo New Super Mario Bros. for DS Logo
122 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
