Question about Proscan 32LA25Q 32 in. LCD TV
I can not find the numbers to program my Compass remote for this TV proscan LA@%Q all (5) five codes do not ork
  • 2 more comments
  • maheuxm754 Jul 17, 2009
    I will check this 2 codes tomorrow I will give you news
    Marcel
    The original remote for the tv is ONEWRMTOO68 3 number are ok. But the remote of motorola dct6416 is a comcast and it accept only 5 numbers for programming. At 3 or 4 wehave an error message
    the original remote is ONEWRMT0068. 3 NUMBERS ARE OK FOR CODE. I HAVE A COMCAST REMOTE FOR THE MOTOROLA DCT6416 AND IT IS NECESSARY TO HAVE 5 NUMBERS FOR PROGRAMMATION. aT 3 OR 4 WE HAVE AN ERROR MESSAGE.
    tHANKS
    Comcast / Motorola HDTV DVR Cable Remote Control
    President:
  • 2,777 Answers
There should be some "Generic" codes on the list there, make sure you try those. Make sure you try just 000. Also, try 181.
I am researching some more, let me know what you come up with from those.
Thanks
Tim
Posted on Jul 17, 2009
  • 1 more comment
  • Tim Grayson
    Tim Grayson Jul 17, 2009
    Sounds good, you already rated me poorly on the other version of your question, please hold back your judgment on this one =).
    Thanks
    Tim
  • Tim Grayson
    You can try adding a few 0's in front of or behind the 3 digits. Also, which remote is it that you have exactly, is it on this list?
    http://www.comcast.com/corporate/custome...
    Thanks
    Tim
  • Tim Grayson
    Ok, try the first set of steps here with the code 0047, if that doesn't work do the code search as described in the second portion:
    Setting a Device Code
    1. Find the 4-digit code number for your device.
    2. Manually turn on the device you are setting the code for (used to verify you have the proper code).
    3. Press and release the device key you want to program.
    4. Press and hold the "Setup" key until device key blinks twice.
    5. Type in the 4-digit code using the number keys.
    6. If successful, you will get 2 blinks. If not successful, you get one long blink.
    7. Use the remote to operate your device (use Power, Play, etc..)
    8. If it doesn't work, look for another code and repeat the above.
    • The code for the DVR box is typically 1376 or 0476 (or 01376 or 00476 for models accepting five-digit codes).
    Searching for a Device Code
    If you couldn't find a code for your device, or none of the listed
    codes work, you can try a Code Search. This will step through every
    code, sending a key until you find one that works, or it cycles back to
    the beginning.
    1. Manually turn on the device you are setting the code for (used to verify you have the proper code).
    2. Press and release the device key you want to program.
    3. Press and hold the "Setup" key until device key blinks twice.
    4. Type in the code 991. The device key should blink twice.
    5. Aim the remote at the device and press Power (or Play or some other key that will give an obvious result.)
    6. If there is no response, press the device key.
    7. Keep repeating the Power (or other) key and device key until you get a response.
    8. If you do get a response, press the "Setup" key to lock the code.
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
Saludos necesito los codigos para el control remoto de dish, tv Proscan modelo pld3283d. Agradecida por la ayuda que me pueda dar.
002,007,000,018,052,011. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 10, 2013 | DISH Network IR Remote Control
Programming comcast remote
the codes for the remote to access a Proscan TV are as follows: 11447, 10047, or 11347. I assume you know how to get into the remotes coding mode, but if you don't Here is how you go about it press setup, then press and hold the TV button until the light flashes then input one of the code sets, then if you get a confirming flash hit the power button if the TV turns off your golden if it didn't repeat the cycle with the next set of numbers I gave you. if after you have tried all three numbers you still can't get the TV to react to the remote you will need to call 1-800-COMCAST and speak to someone on their technical staff.
Dec 08, 2009 | Proscan 32LC30S60 LCD TV
Program Directv remote to operate the Proscan TV
The Proscan is an RCA product so the codes are:
10047, 10466, 11347, 11447, 10018, 10019, 10038, 10047, 1090, 1135, 10679, 11047, 11147, 11247, 11347, 11447, 11547
1. Turn on the TV
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under TV flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of TV being set up. If performed correctly, the green light under the selected position lashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
If this helps please rate my response. Have a wonderful day!!
Jun 27, 2009 | Proscan Televison & Video
I can't program a Direct TV remote for Proscan TV
Found these codes on the website for PROSCAN. www.oncorpus.com, for youmodel television.I hope this help you with your problem. UNIVERSALREMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
May 16, 2009 | Proscan 32LA30Q Television
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
Feb 17, 2009 | Proscan 32LA30Q Television
HOW TO OPERATE PROSCAN REMOTE MODEL CRK76DBL1..
I still have not figured out how to program the exact code in the crk76DBL1.
However, I did figure out how to use the code search for the TV
1) Turn on the component you want to control (TV, VCR, DVD)
2) Press and hold BOTH the component button on the remote and the On-Off button
3) The On-Off button remains lit. Now press Play (The On-Off button will blink)
4) If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
5) When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
6) To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
I hope everyone finds this helpful and saves people time and frustration.
Feb 22, 2008 | RCA DIRECTV Satellite Remote Control
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Proscan 32LA25Q 32 in. LCD TV Logo
54 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
