Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Scanner is jammed
The scanner is jammed on the left after i last scan a document, now it prompt scanned locked unlock scanner
There is usually a scanner lock button on these units, either located under the Auto feeder on the left side, or on the left side of the machine
Posted on Jul 17, 2009
Please solve the problem of 5600/5650 usb scanner please verify that you have UNLOCKED the scanner hardware . The lock is located on the bottom of scanner click ok after you have unlocked the scanner
I have a scanner 5600/5650 UMAX , but it has been started problem since last one week and the scanning of document can not be possible give me solution
May 11, 2012 | Umax Astra 5600 Scanner
How can I fix -->290.02 scanner jam<-- there is no paper jam, or paper to scan.. every time i try to fax a document, the rollers on top keep rolling after last paper and imediatelly gives me that...
their is a lock lever or mechanism underneath the scanner on the left front or o the rear that needs to be unlocked so that your scanner can move freely.
Oct 11, 2010 | Lexmark X364dn All-In-One Laser Printer
I am repeatedly getting error code 5010 once I scan any document.
Ok it can be either 2 things: The FIRST is if you have not UNLOCKED the scanner lock switch. The scanner lock switch is a switch that keeps the scanner assembly frozen in place so that when you move your scanner from room to room or apartment to house, the scanner wont freely move around the unit causing it to be dammaged.
To unlock the Scanner lock switch just lift your document cover and look for the swtch on the LEFT hand side of the scanner's glass bed.
SECOND: IF the scanner lock swtich is set at UNLOCK, then your scanner assembly is broken and needs to be replaced. You must then send it to Cannon or any Mulitfunction printer repair place.
I hope this helps you :)
Mar 15, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I dont know how to scan
HI, The easiest procedure to scan a document using your scanner is open Paintbrush that is installed with your operating system. Click on File Menu at the top left corner of your screen, then select "From Scanner or Camera". Once you have selected the option, you will be prompted for your scanner. Select the installed scanner and go on scanning the image/document placed on the glass bed of your scanner. Once the scanning has been completed, save the image file.
Cheers!
Mar 06, 2010 | HP Photosmart C5180 All-In-One InkJet...
My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is...
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
May 22, 2009 | Office Equipment & Supplies
Scanner won't feed
Fan the documents and check if they are loose. Stapled documents can be 'sticky' even after removing pins. Clena the pick-& ****** up rollers. Switch off the scanner and rotate them by hand so that all areas canbe cleaned (In power-on position, they are locked), If worhout replace them. Normally they last about 250,000 scans. Using a damp cloth is generally enough, dont use solvents.
S. Mohan, India
May 20, 2009 | Canon CD-4050 Path-Through Scanner
Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
Dec 25, 2008 | Samsung CLX 3160fn All-In-One Printer
E9 code
E9 code means there is a paper jam.
Clearing Paper Jams
If your scanner stops scanning due to a paper jam in the Automatic
Document Feeder, a warning dialog box opens after a few
moments.
To clear a paper jam:
1. Press the ADF cover release on the top-left of the scanner
body to open the Automatic Document Feeder cover.
2. Remove the jammed paper and close the cover.
To reduce the number of paper jams, smooth and straighten the
paper before scanning and adjust the guides to the paper size.
This should help. Please let me know if it does. Thank you, Binary Bob
Dec 04, 2008 | Xerox DocuMate 252 Path-Through Scanner
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
Scanner not scanning
Your 'transportation locks' may have been engaged. (Check lower-left-hand-corner of the inside the scanner cover and the left-back side) See the manual: http://files.support.epson.com/htmldocs/pr48ph/pr48phrf/maint_3.htm
May 27, 2007 | Epson Perfection 4870 PRO Flatbed Scanner
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
184 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
