Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Dryer will not dry clothes
Dryer appears to operate correctly. OPen the door and the interior is hot, but no air flow coming out of the house vent line. I cannot see a blockage.
    President:
  • 1,273 Answers
Hello. Unplug your dryer. Remove your vent duct hose and, holding it like a "U", take it outside and clean it out. While the duct is removed, inspect the dryer exhaust (where it goes into the duct) and the other end (where it passes through the wall). Clean and remove any debris that you find. Remove the lint filter and check for debris in this cavity as well. If you find and clear any debris, this may get you drying better.
There are other things that might be at issue, but this is the most common and most easily repairable. Please repost after giving this a whirl.....Operators are standing by!!!!
Regards, --W/D--
Posted on Jul 17, 2009
Clothes dryer overheating?
use your dryer on air dry only (not heat dry) run about 2 min. check if your dryer is hot, that is heating element is short to ground and if your dryer is cold, check your dryer air venting system. (open the door if you see lint on door panel, it is a sing of bad air flow, it is dangerous to fire) hope its help.
Jul 10, 2014 | Whirlpool Dryers
I have a Sears Kenmore Gas Dryer Model Number 110 72612101 Serial Number MM2606191 that appears to be over-heating. All my clothes come out smelling like burnt rubber and/or dry cleaning compound. If I put...
I suspect the vent is the issue with your dryer. It sounds like the air is not moving to the outside well and is keeping the interior too hot. The filter housing may also be plugged. Make sure the vent is clear all the way to the outside. Be certain that the hose is not kinked or crushed behind the dryer and is as short as possible. You may change the operating thermostat as well.
Kelly
Mar 21, 2011 | Kenmore Dryers
Dryer gets hot but does not dry. It seems to keep the moisture in as of there isn't any air flow. I cleaned out the vents and air duct but still wont dry
This definitely sounds like a clogged vent. 1) disconnect the vent from the back of the dryer. Turn the dryer on and make sure your getting good air flow from the vent outlet. 2) if the air flow is good then your definitely have a vent that is clogged between the dryer and the outside of the house. This is the most common cause for the dryer to not dry the clothes.
Jan 13, 2011 | Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
AF Code flashes briefly; Clothes don't dry - vent clear
Remove the back of the dryer and chek the lint filter area from the lint catching filter to the exhaust tube. There is a blockage in airflow even though you feel the air at the exhaust there still insn't enough air flow to allow the proper drying of the clothes. This symptom that you gave clothes being hot but not dry the only cause for this is improper air flow
Dave
Mar 31, 2010 | Dryers
My dryer seems to be overheating? It is very hot and taking a long time to dry my clothes. When I open the door there is alot of steam coming out. Any suggestions?
This is commonly caused by a clog in the exhaust vent ducting. If you have not inspected the ducting any time recently, now may be a good time to do so.
The problem can also be internal. If the blower fan assembly becomes clogged, it can exhibit the same symptoms due to poor air flow.
A simple test you can try is to remove the exhaust vent hose from the back of the dryer and try drying a load as you normally would. The air flow leaving the back of the dryer should be warm and forceful.
If the air flow is normal and your clothes dry like they should, you have a clog or restriction somewhere in the exhaust vent from the point where it leaves to dryer, to where it exits your home. You will need to inspect and clean as necessary.
NOTE: The exhaust should be at least 12 inches from the ground to prevent rodent intrusion. If you use an exhaust vent cover, make sure it is the louvered variety. Using any type of screen can clog easily. In addition, you should be using the semi-rigid metal type ducting. It resists kinking, crushing and rodent infestation. A kinked hose can exhibit the same symptoms as a clogged dryer.
If the air flow is weak, you have an internal clog. You will need to access your dryer air blower assembly to ensure the fan is moving properly and it not clogged. Rodents are notorious for building nests in these areas and blocking the air flow.
A clogged dryer will actually over heat, because these is no air flow to keep the heat circulating. The result is a dryer that appears to be very hot, but the clothes take longer times than usual to dry. If left in this condition, the heating circuits will eventually fail.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Oct 12, 2009 | Kenmore Elite 20972
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Washing Machines Logo
131 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
