Hi Renu, it's Jack at Dyson.
If your AM06 isn't working at all, it's worth checking it using different power outlets, just to make sure the socket itself isn't at fault. Please also check to see if the machine displays any error codes on it's LED display, as this will provide more insight into what the issue could be.
For further help, please get in touch directly. If a replacement part is needed, we'll be able to confirm if this is covered under your Dyson 2-year warranty. You can reach us by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
We'll look forward to speaking with you.
Inside the wiring of the motor is allways a thermal fuse in included by manufacture and its inside or a heat shrink or an colored kind of seal like every transformer have inside it it is to fireprotect , if you every time if after a long time not used the fan will start then take a little wd40 every time on the shaft then it function for years because the sintra sleeve bearings can become dry and tough and the motor draws excitement and then the thermal fuse blows. to protect your home for fire replace only with the same tempfuse and do not forget to take between the legs use pliers between the soldering tip that pulls the solder heat directly into the fuse because otherwise directly broken
