Question about Emerson Heating & Cooling
I Have an eqk 1400-a Roof mount airconditioner in my rv that was working great,& now stopped blowing cold air! What is the most probable cause,& would it be cheaper just to buy a window mount rather than to fix it?
motor1258
  • 6674 Answers
SOURCE: roof gasket on rv a/c
Try not to compress gasket past 1/2 it's original thickness. Most of the factory ones have tabs that stick down, and supposedly when they touch the roof, it's far enough, which is about same as 1/2. I use my cordless with the torque setting on it, at about 2-3 until I see how far that draws down, then increase/decrease as needed from there.Once i feel it's 1/2 way, I torque all at same setting on drill to make sure all equal.
Posted on Aug 15, 2008
  • 17 Answers
SOURCE: Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Posted on Jun 06, 2009
  • 82 Answers
SOURCE: coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Posted on Jun 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: coleman rv roof mount a/c compressor runs all the
Replace the thermostat.
Posted on Jul 20, 2009
motor1258
  • 6674 Answers
SOURCE: coleman tsr roof ac does not cool 27' rv i've
Is this a new unit/RV by any chance?
Posted on Jul 23, 2009
15,000 btu roof mount 2nd ac nonducted cycles about every 5 or so mins ice cold air for about 1 mins
Have you checked location of probe for return air? Remove filters and find probe to make sure it is about in the middle of flow of return air. Let me know what you find.
Jan 12, 2013 | Dometic Rooftop RV Air Conditioner
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic RV airconditioner roof mounted, the model number shown on a tag inside the unit says it is Model CAL 136.312 Product Number 991650423, I cannot find this model in the Dometic catalogue is...
Your probably looking at the control module number or something in that area. When you have the ceiling assy off as in cleaning filters, look for a sticker directly on the base of the roof unit. Look all around on that base, even behind wiring harness, you should find a model number and serial number.
Jun 08, 2010 | Dometic Rooftop RV Air Conditioner
The airconditioner runs and blows cold ai. When
Hi, the only thing that could cause this to happen would be the thermostat. This is the main part that controls the roof top unit, getting its signal from the stat to come on and maintain the correct temperature. I would replace it with the same type and this will solve your problem. The only other thing that would cause any unit to cycle like this is if you had bad thermostat wiring touching together some where. I don't think this is the problem with yours though. With the stat off and it still cycles on, this tells me for sure it is the stat. Change it out and you will be good again.
Sincerely,
Shastalaker7
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
Coleman mach 3 rv roof mount ac
You will need 12 vdc (battery or converter) for controls to work, and 115 VAC (hydro) for fan & compressor to work. With your fan obviously working, that tells me you have both already but compressor may not be kicking in. Do you hear a "moaning" sound or see lights dim when switched to cool?
Aug 17, 2009 | Coleman Mach III Air Conditioner
Fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Condensation leaks inside rv
maybe thermostat setting is too low moisture builds up fast enough, recommend @22C/ 74F
May 19, 2009 | Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
