Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Freezer not freezing ice cream and milk
I have a fridaire fridge with top freezer. Freezer is cold enough and makes ice as well but the ice cream does not stay solid and the milk doesnt freeze either. Would appreciate if someone can provide a solution.
  • 286 Answers
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Posted on Jul 17, 2009
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 17, 2014 | Frigidaire Refrigerators
Westinghouse RJ275M 194l fridge with top 81l freezer doesn't keep the fridge cold anymore. Freezer is fine. is it the thermostat?
If the upper compartment, the freezer part is open on the ends and the rest of the refrigerator is cold enough, that can't be fixed. If the the box is closed on the ends seperate, check the flow control of air if it has one, check the thermostat and set it till things nearly freeze in the lower non frozen section. If all this doesn't work and you can't keep the ice cream turning to milk, gotta get a new refrigerator.
Nov 25, 2010 | Westinghouse Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
532 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
