Question about Garden
I have a dsl 3500 craftman riding lawn mower 46'' precision plus deck ,when mowing it has an noise sounds like a belt, but the belts check out ok thanks for help
I jave a craftsman dsl3500 riding mower and while mowing one of the baldes came off and the engine stopped runing it started back up then it stopped again can anyone solve this crazy problem
Posted on Apr 19, 2010
    Problem Solver:
  • 12 Answers
HAVE YOU CHECKED THE BECK BEARINGS?
Posted on Jul 29, 2009
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
My craftmans 46 in cut (22 hp) tractor goes backward after I changed drive belt
If you notice how the belt leaves the motor pully and goes to the transmission, it makes a 1/2 twist? Well reverse that twist and the tractor will go in the correct direction.
Jul 03, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftman 46in deck model#917-27201 how do you replace the deck belt i would like a diagram please
there is a sticker on the deck that shows the routing for the belt - on a 46" deck, it's probably on the rear, center - or it could be on the underside of the left running board
Jul 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
46 inch cub cadet mowing deck need diagram for belt
Go to... http://www.partstree.com/parts/ Click on the Cub Cadet logo then enter your model number. All the diagrams are there.
Jun 11, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
423 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
