ATVs Logo
Shane Marshall Posted on Apr 27, 2016
Testing pickup on Yamaha prohauler - ATVs
2answers
1989 Yamaha blaster 200 no spark
Silly questions! Is this a kick or button start? Is there a security 'Dead' switch fitted to the ATV that you have left on? Have you changed the actual spark plug? Is the Battery fully charged? Turn all the other features off that you can on the ATV before you start it. This stops any other drains on the voltage at starting.
Oct 15, 2021 • ATVs
2006 Yamaha 660 grizzly.turn key on, turn on run switch, all lights on display turn off. Can squeeze brake lever or try light switch, everything turns off. What could it be? Checked fuses, wires,...
If you have not done any wiring repairs and this problem has just seemed to have developed , then I am guessing you have a live wire that is touching another wire or bare metal of the frame , handlebars or some wires are plugged into a wrong connection ! You can search the internet for a wiring diagram for your bike and should be able to find one for free ,but it will cost you time ! try a Yamaha motorcycle site where members have open forums or use google images just type in your bikes info model etc and add wiring diagram ! But if you own a motorcycle I would strongly advise you to purchase a workshop manual (it does not have to be a genuine Yamaha manual ) as there are manuals for most bikes and the reality is that you should be able to make a huge savings on maintenance and DIY repairs, adjustments etc and with the full wiring diagram that you can follow and relate to will simplify any wiring problems in the future .
My husband has a 1998 350 4x4 Yamaha that is not firing
test: plug, spark plug cap, coil then stator pickup coil.
I was riding my 2005 king quad 700 and it just died and I checked the plug and am getting no spark - would the coil go out just like that
coil, kill switch has grounded itself, pickup coil gone bad, etc. grab a multimeter, a service manual and start testing things.
Dec 28, 2016 • ATVs
2answers
No spark at spark plug could the coil be bad and how do you test it ?
put an insulation screw driver in the wire end that connects to the cap, obviously disconnecting it from the cap. Crank over and move metal part of screw driver next to some metal and you should see a spark coming from the wire to ground if coil is good.
Feb 14, 2016 • ATVs
I have a 2006 yamaha bruin 350. The other my son jumped started my daughters atv and it burned his ground wire up. Now have no fire goin to the coil. any suggestions
I am sure you have replaced the ground wire. Start checking everything from the battery on. Make sure all fuses are good. Sounds like it was jumped from a car, worse thing you can do especially it it is running. Could just be the coil. If not, cdi possible too. Are you getting power to all of your lights and everything now just no spark? If you can find a donor coil to check, make sure all of your grounds are good to the motor too. Google for testing specs on that model for the cdi.
Aug 03, 2015 • ATVs
Testing pickup coil
you'll need a multimeter and service manual to tell you what wires to check and what resistances to expect. its pretty easy to do.
My 1998 yamaha warrior atv isnt starting the starter is turning the crankshaft but the spark plug isnt getting any spark. My mechanic says that the catch coil in the magneto system could be junk but he...
There is no voltage specification listed in my manual but it does specify that the charge coil resistance test should be between 270 - 330 ohms and the pulse(pickup) coil should test from 171 - 209 ohms, figures listed are for coils around room temperature of 20 degress celcius
How to trouble shoot just the cdi unit on a yahama yfb250e--1993
Yamaha ignition coils never go bad. It is probably the Stator/ Pulser coil (very common). You can check them with a ohm meter. You'll need the readings from a Yamaha dealership. The CDI box is very seldom bad But there is no checks that can be done on it. If everything else is fine ---than Yamaha says it must be the CDI box.(Rare)
Top ATVs Experts
john h
Dmitry Isayev
Dmitry Isayev
Are you an ATV Expert? Answer questions, earn points and help others
