Question about Kitchen Ranges
I am looking for an ignition module for an Explorer brand gas range. I have searched for the part and unable to find. The module is made by Ispracontrols and is model BK40085-00.
4 Suggested Answers
huuum
  • 750 Answers
SOURCE: Tappan gas range burner ignition
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine.
What do you need to do to fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Huum
Posted on Sep 24, 2008
duby1990
  • 367 Answers
SOURCE: Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Burners on a GE Spectra JGBP30 Gas range don't ignite
Try this link and download PDF has numbers and answers
http://lib.store.yahoo.net/lib/usappliance/JGBP35manual.pdf
Posted on Jan 31, 2009
560s111po1
I would do an online search for appliance parts (example = http://www.appliancepartspros.com/ ) ; contact them directly and inquire.
As well since Sears has this as a private label brand, I would contact the one closest to you and have the appliance manager locate the part for you.
Oct 09, 2013 | Kenmore 72620 / 72621 / 72624 Gas Kitchen...
Broken Ignitor module
Patricia, if you're talking about the oven igniter and it's rectangular in shape (not round) the part number is WB2X9998 and lists for about $40.00. This is an igniter built by GE, but is universal to all brands using this style igniter and is available at any local appliance part retailer. But, if your talking about a "spark module"... I'll need the full model number to help you further. (B0613 didn't show up in my data) Hint---> before removing an oven igniter, apply a few drops of dish washing liquid to the threads of the fasteners. This will act as a lubricant and allow the fasteners to be removed without stripping or hassle and (after the job is done) won't smell bad when you use your oven again.
Sep 27, 2007 | Explorer Appliances BO613 Stainless Steel...
Range has electric igntion and it will not heat. the ignition and burner will cycle on intermittently then it would shut off. it would do this for 3 times. its a imperial convection oven IHR-4-C model. was...
It sounds like your ignition module is unable to prove flame for some reason. This could be caused by poor positioning of the flame sensor, a bad ground to the burner or to the ignition module. If the flame is not engulfing the flame sensor on the ignitor, the module will attempt to light three times and then lock out. Poor air flow or too much air flow through the burner compartment can blow the flame away from the ignitor as well. Hope this help
May 17, 2011 | Imperial Commercial Cooking Equipment...
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Gas range won't ignite. We had PGE and come over
This sounds like a failed burner igniter, also called a spark module. These are pretty easy to replace since the module itself is located at the back of the stove under an access panel. The price is around 40 to 60 dollars. Lately it seems that these newer stoves have weaker spark modules. I see dead modules on models less than 2 years old, where it used to be more like 5 or more years on the older ones.
Mar 24, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Where is pilot light exactly
If the model number you have this posted under is correct, your range (as well as most all modern ranges) does not have a pilot light. The range uses spark type igniters that are controlled by a spark module for the surface burners and a glow bar type igniter for the oven. The gas flow is controlled by a gas pressure regulator through a safety valve. You can view the burner lay-out for a Tappan range at the following link:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=TGF303BWA&productCategoryId=0124002&brandId=1269&modelName=GAS-RANGE&diagramPageId=00002&componentDescription=BURNER&documentId=R0302024&backToLink=Return%20to%20Sub%20Components%20list
If the link does not work, go to searspartsdirect.com and type in your model number. Look under the "Burner" heading to view your range configuration. The spark module is listed a item 8, the surface igniters are listed as item 11A and the oven igniter is listed as item 19. If you need further assistance, please let me know. I hope this helps you.
Jun 24, 2009 | Tappan TGF303BW Gas Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter
Hello rico49.
Welcome to Fixya.
Please send me the Brand,model number , and year of your range
Huuum
Oct 02, 2008 | Kitchen Ranges
All the stove top ignitiers work intermitantly.
If ALL the igniters are affected in the same way, I would suspect a spark module that is going bad. All the top igniters are the spark type and are fed by a spark module located either behind the bottom drawer or behind panel on the back of the range. Repairclinic.com carries the part for about $65. Just type in your COMPLETE model number in the Search menu and scroll through the pictorial list of parts for a "Spark Module". You can also try searspartsdirect.com. They also carry an inventory of parts for quite a few name brands. I hope this helps you. Please post back if you need further assistance.
Apr 07, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
