Question about Dell The Print Shop 20 Deluxe for PC
Can you run print shop 20 deluxe from an LUA Account?
Can you run print shop 20 deluxe from an account on Win XP that is not an administrator account?
    President:
  • 828 Answers
Yes it is but before continuing to install print shop by other account make sure that your account is not limited access to install...
Posted on Jul 17, 2009
I have administrator on user name and cannot get
You didn't mention the Operating System you're running. But if you can't login to the Administrator account - you won't be able to add another user account. In XP, if there's no password set, you can login to the Administrator account by booting into Safe Mode. In Vista, Win 7, and Win 8 Administrator account is disabled by default. You can enable the account, and blank the password, by booting from a CD or thumb drive created with the following program: http://pogostick.net/~pnh/ntpasswd/
Oct 01, 2014 | Computers & Internet
I have an old Print Shop 6.0 OEM Special Edition I have been using forever. I have Vista premium It just quit. I uninstalled it but it won't reinstall. It says "product identification file is missing or...
The program must be installed in an Administrator account and must be run in compatibility mode.
To check if you are using an Administrator account use the following steps:
1. Click on Start, then Control Panel
2. Open user accounts then select your Account
3. If it says Administrator you are finished, if not continue to step 4
4. Select Change your Account type, then choose administrator.
5. Click Ok.
6. Reboot computer and install.
Once the install is complete, follow these steps to run in compatibility mode:
1. Right click on desktop shortcut, then select properties
2. Click Compatibility tab, then check the box that says Run this program in compatibility mode for:
3. It should default to Windows XP (Service pack 3). leave it there.
4. Click Ok.
This should resolve your issue. If it does not, either you have a bad install disc or you will need to perform a completely clean install of Print Shop, which is signficantly more involved.
Nov 20, 2013 | Computers & Internet
I cannot format my external disk: WD My Book 1110 Essential Edition WCAV57909867 1TB. It looks protected for writing. The disk, tested with WinDig.exe, results good. Taken to the shop where I bought it,...
formatting looks possible??? with xp and vista
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
hope this helps you
Aug 18, 2011 | Western Digital 500gb Mybook Essentials...
I have the full version of print shop deluxe22 and it won't let me install it on my hp laptop HP G71-442nr Notebook, Running windows 7
Print Shop 22 Deluxe is not compatible with Win 7 (x86 or x64bit) Operating.
You have to use the Print Shop 22 Deluxe version 23.1 - compatible with Win 7 & Vista.
Hope it helps.
May 25, 2011 | Broderbund The Print Shop 22 Deluxe Full...
I purchased printshop 20 deluxe and installed on my computer which has windows 7 installed on it. The installation shows it was successful however when I try to run the printshop program it tries to start...
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
Mar 14, 2011 | Broderbund The Print Shop 20 Deluxe for PC
Making printshop 21 run properly on win 7
You can either get Broderbund Print Shop Deluxe 2.0 which is Win7 compatible or use a virtual/dual boot computer with WinXP. (The Vista compatible version was Print Shop 23; so you are dealing with some significant changes in the OS. Thus the compatibility mode probably won't work. You can try right clicking on the installer and choose Properties and the Compatibility Tab. Check Run as Compatible with XP then right click on the installer again and choose Run as Administrator. Then do the Compatiblity mode again with the actual program.)
With Win7 Pro and Ultimate, you have an option to download and run XP mode which takes two programs that you download from Microsoft and install. This lets you run a virtual XP computer inside the Win7 computer for free. All other virtual computer programs or dual boot systems require a licensed version of XP.
I hope this helps.
Jul 31, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Print Shop 2.0 Deluxe will not load.
Have you tried installing them in Compatibility Mode? If not, look in
Vista's Help
& Support for how to try this. If that doesn't work, you can
try installing them as Administrator by right-clicking on the installer
executable and choosing "run as Administrator".
If none of that works, I'm sorry but you'll need to update to a current
version of the program that the mftr. says will work in Vista.
Jan 30, 2010 | Broderbund The Print Shop 20 Deluxe for PC
Avery DesignPro Error while initialising
Reinstalling and restarting won't solve the problem. For some reason Avery design pro limited attaches it self to windows user account. You can create another windows user account and run the program and it will work. When you start the program in the new windows user account it will ask you for your name "Author Name".
Mar 14, 2008 | Avery DesignPro Deluxe CD-ROM...
Dell The Print Shop 20 Deluxe for PC Logo
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
