I have a kenmore elite dryer that is only 4 yrs old. It stops about 5 minutes into the cycle and puts up 2 codes. CLL and Sru what do these codes mean and can I continue using the dryer ?
Re: I have a kenmore elite dryer that is only 4 yrs old. ...
Clean the entire exhaust duct from the back of the machine all the way out of the house, if the codes don't change. Call a service tech... CLL SRV = call for service
The serial number is just a numerical reference of when it was made. The Model number is the import part.
Kenmore dryer will run for approximately five minutes. It then stops and throws a CLL SRU error code. I have researched this to mean "Call for Service". I have seen others potential causes that range from shorted heating element, to dirty lint screen/venting.
are u saying it shuts down or just stops heating? if it shuts down u may have bad motor windings and or brushes and motor is burning out if its stops heating that is usually due to bad moister sensor, cycling thermostat ( which would not usually shut appliance off though), short in heating element, defective hi limit thermostat etc and of course u already said u cleaned lint and ducts? including the blower? if its blocked with lint u have a shut off issue
Most likely a broken wire in the dual heating element. Pull the cover off the machine, with the power cord unplugged and put a voltmeter on Ohms checking for continuity of the elements. Also check the overheat fuse(s) for continuity.
Check for clogged or restrictions in the exhaust vent. I had a bees nest once on the outside which restricted the door on the vent from fully opening, which lead to an overheat condition.
Re: Kenmore Elite 417; error CLL SRV
We have well water and I think my error message and locked door were because the machine was trying to plump water and not getting any. I heard the error beeping and sent to check it out. There was another noise that didn't stop even after unplugging the washer, although the beeping did, which finally stopped after I turned off the water valves. Press and Hold the power button down to unlock the door and retry. If you still have trouble, call for service.
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
