The elna 7000 is an electronic machine. I can select the differnt stiches etc, but it only stich forward and does not stich the selected stich. It stiches very slow, but not the selected stich, and only forward not backwards. Could it be due to not enough oil, as i did not use the machine for quite some time and did not oil it before use?
Looks like this is a mechanical machine. If so, bet it needs a good cleaning and oiling. The following may be helpful:
It was working now it seems to be frozen the needle part wont move
Definitely get some good quality sewing machine oil. Sounds like the machine has basically seized, including the stitch selectors.
Testimonial: "Thanks for the reply! I do not know how to reply to your answer, but i edit the question to give some more info if you can have a look at the question now? Thanks."
SOURCE: ELNA 7000 SEWING MACHINE
If you bend over the front of the machine, you will see a slider switch on the back of the machine, and there is a small "button" at the bottom right of the switch (your right). If you push this button down, you can slide the slider switch to your right and the feed dogs will go up.
SOURCE: elna 7000 computerized sewing machine
just wonted to see how much these elna 7000 are running now i have one but i just wonted to see what its worth now
SOURCE: sewing machine stopped making the stich
Unthread the needles, rethread the loopers properly, then rethread the needles. Make sure that all four threads are pulled securely into the tensions and retry.
The loopers must always be threaded before the needles or it will not chain.
SOURCE: free manual for Elna 7000 sewing machine
hello, I don't know if you have found a manual yet, but I have the elna 7000 and it's manual.I could copy mages and send as an attachment as a last resort for you. I am giving the machine and all its many books to my daughter in law,
