Cannot detect other printer in remote desktop connection
Hello, just set up a remote desktop connection. But when connecting remotely, remote connection cannot detect the local printer.(Canon LBP2900 and Samsung ML-2240) Both printers are shared. Other LPT printers are detected.
I'm using windows server 2008 and the client is using windows xp home SP2.
Tried this, http://searchwarp.com/swa33459.html, but did not work for canon and samsung.
Tried this, http://www.vistax64.com/vista-print-fax-scan/143174-found-solution-having-canon-printers-compatible-microsofts-remote-desktop.html, but when browsing for printer under tsclient, no printer was detected.
Thanks.
  • chris Oct 16, 2009
    @geo_jonas: your solution worked for Samsung ML 2240 bt not for Canon LBP2900.
    Now I have the same problem with HP D2560. I'm trying to install the printer manually on the server but I cannot find the D2560 model on the list of HP printers.
    Can anyone help?
    Thanks in advance.
We also had the same problem with Canon printer and then we found great solutionat http://terminalworks.com/remote-desktop-printing. working great, low pricean no problems anymore. hope it helps
Posted on Mar 04, 2012
  • 555 Answers
Hello my friend, regarding on your problem kindly check your system particularly your windows 2008 server OS. Kind reinstall the printer drivers then then shared it. Then after you share the printers kindly check the ip address of your windows server 2008 OS then go to the workstation Computer then click start button found in your task bar manager then click run. Then kindly type the "\\IP of your windows server 2008" where your printer drivers installed then enter. As soon as you can log in the Windows server 2008 menu environment then if you can find or see the printer icon then click the printers icon then right click then click connect. Let the system automatically installed the printer driver to your workstation computer. then as soon as your system finished installed the printer drivers then try to run and print if you can now print using network LAN.
Hope this solution able to solve your problem. If you need more assistance kindly rely to this post.
Thank you.
geo_jonas
Posted on Jul 17, 2009
Is there any software by which i can work on my computer when i am away from my home ?
Hello,you can work with your pc even away from it without a software.. In Windows, Remote Desktop allows you to access your computer from a remote location. To enable Remote Desktop, you must have administrative rights on the computer you want to use as the host (i.e., the computer to which you will connect from a remote location), which must be running one of the following versions of Windows: Windows 7 Professional, Enterprise, or Ultimate Windows Vista Business, Enterprise, or Ultimate Windows XP Professional The Remote Desktop Connection client software (for the computer from which you want to connect) is installed by default on all computers running Windows 7, Vista, or XP. Enable the Remote Desktop feature on your host computer From the Start menu, select Control Panel (or Settings, and then Control Panel). Double-click System. In Windows 7 and Vista, click Remote settings. In the "Remote Desktop" section, select one of the two options to allow connections from other computers. In Windows XP, select the Remote tab. Select Allow users to connect remotely to this computer. To choose which users will have remote access, in 7 and Vista, click Select Users... or in XP, click Select Remote Users... . Typically, all administrators of the computer will have access by default. Each user must have a password before you can allow remote access. When you are finished, click OK. Your computer will now be able to accept incoming Remote Desktop connections. Open a connection If you have configured your computer to accept remote connections, to establish a Remote Desktop connection: Depending upon your network configuration and system requirements, you may first have to establish a VPN connection to your host computer's network. From the Start menu, select Programs or All Programs. Select Accessories, and then Remote Desktop Connection. In the space next to "Computer:", type the name or IP address for your host computer. Click Connect. Note: If you would like to adjust any of your connection settings such as screen size, login information, availability of local hard drives and printers, or keyboard and sound behavior, click Options before clicking Connect. In the Log On to Windows dialog box, type your username, password, and domain (if required). Click OK. Once you are connected, you can use your remote computer as if you were sitting in front of it. When you are finished, in the Remote Desktop Connection window, select Start, then Shut Down. In the Shut Down Windows dialog box, from the drop-down menu, select Log Off username, where username is your username on the remote computer. Click OK. goodluck!don't forget to rate,thanks'''''****
Feb 21, 2011 | ViewSonic VG2230WM LCD Monitor
Tip
How to Enable Windows 7 to make a Remote Desktop Connection
1. Go to Control Panel>System>Advanced System Settings
2. Go to Remote tab.
3. Under Remote Assistance, put a check mark on Allow Remote Assistance connections to this computer.
Note: This automatically adds Remote Desktop exception to Windows Firewall.
4. Click on Apply.
1. Go to Start>All Programs>Accessories>Remote Desktop Connection
2. Enter the Computer Name or IP address of the computer you wish to connect to.
3. Click on Connect.
4. For more connection options, click on Options
Here you can save the connection profile, adjust display properties, run specified programs upon connection, adjust connection bandwidth, etc.
For more information on specific tabs, click on Help.
on Mar 23, 2010 | Computers & Internet
How do I setup Remote Desktop Service
I assume that the the computer on which you want the Remote desktop and the target computer whose desktop you want to capture are networked properly and the IP address with other TCP/IP settings are properly configured.
That said Go to Start and click Run the Run box will appear. In the run box type "mstsc" command to connect. A box will pop up asking for the "Computer" enter the computer name or more preferably the IP address which you want to connect to and capture the desktop remotely the Target computer.
Go to the target computer physically and right click the "My Computer" icon and then in the menu select the properties tab and click it you will see "System Properties" window pop up. On the top you will see some tabs. Select and click the "Remote" tab. At the Remote Desktop make sure that the "Allow users to connect remotely to this computer" check mark is selected if it is not ticked tick it. This is the way you are allowing your computer and other computers on the network to connect to this target computer.
Now go back to your computer click the connect tab.It should always connect as long as you give the correct IP or computer name in the "Remote desktop connection" box.
Best of Luck!!!
Jul 30, 2010 | Microsoft Windows XP Professional for PC
When I try to connect to the internet it says the remote device won't except the connection
Please follow the following steps.
1. Open up your internet explorer and click on Tools tab 2. Click on Internet Options Tab 3. Click on Connections tab 4. Click in Lan Settings tab 5. Uncheck the box Automatically detect settings 6. Also uncheck the two boxes under Proxy 7. Click OK 8. Hopefully it will resolve your problem
Jun 09, 2010 | Computers & Internet
How do i connect this terminal to windows 2003 server please give me the settings
Open Remote Desktop Connection loadTOCNode(2, 'summary'); To open Remote Desktop Connection, click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Create a Terminal Services Connection loadTOCNode(2, 'summary'); To create a Terminal Services connection, follow these steps:
  1. Open Remote Desktop Connection.
  2. In the Computer box, type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
    Note: To connect to the console session of the remote computer, type computername or IP address /console.
  3. Click Connect.
  4. In the Log On to Windows dialog box, type your user name, password, and domain (if necessary), and then click OK.
Save Connection Settings loadTOCNode(2, 'summary'); You can save a connection as a Remote Desktop protocol (.rdp) file. An .rdp file contains all the information for a connection to a terminal server, including the Options settings that were configured when the file was saved. You can customize any number of .rdp files, including files for connecting to the same server with different settings. For example, you can save a file that connects to MyServer in full screen mode and another file that connects to the same computer in 800×600 screen size.
To save your connection settings, follow these steps:
  1. Open Remote Desktop Connection, and then click Options.
  2. Specify the connection settings that you want for this connection.
  3. On the General tab, click Save As.
  4. In the File name box, type a file name for the saved connection file, and then click Save.
Note: To edit an .rdp file to change the connections settings it contains, click Start, click My Documents, right-click the file and then click Edit.
Open a Saved Connection loadTOCNode(2, 'summary'); To open a saved connection, follow these steps:
  1. Open Remote Desktop Connection, and then click Open.
  2. Double-click the .rdp file for the connection that you want to open.
Copy Files Between the Local Computer and the Remote Computer loadTOCNode(2, 'summary');
  2. Type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
  3. Click the Local Resources tab, select the Disk Drives check box, and then click Connect.
  4. Click Start on the task bar of the remote computer, and then click My Computer, or double-click the My Computer icon on the desktop of the remote computer.
    Note: The drives on the remote server appear with the drives on your local computer. Your local drives appear as driveletter on tsclient, where tsclient is the name assigned to your (local) computer.
  5. Locate the file that you want to copy, right-click the file, and then click Copy.
  6. Locate the folder where you want to paste the file, and then click Paste.
Log Off and End the Session loadTOCNode(2, 'summary'); To log off and end a session, follow these steps:
  1. In the Remote Desktop Connection window, click Start, and then click Shut Down.
  2. In the Shut Down Windows dialog box, click Log Off username, and then click OK.
Thankyou
Amit Bhardwaj
Skype Id:- amit.bhardwaj4
May 05, 2010 | VXL Instruments Itona CE Windows CE VIA...
Can't print from local printer using remote connection
To print the reports on your local printer, go to
1.Start->Run->
2.Type 'mstsc' and click 'ok'. A window pops up for Remote Desktop Connection
3. Click 'Options' button and select the 'Local Resource' tab.
4. Select the checkbx 'Printers' from the 'Local Device'
5. Click Connect.
Aug 20, 2009 | Actiontec GT701C DSL Modem
Network printer
First you ned to have a print server connected to your router for any network printer to work.
Also, you can set up printer sharing on a computer that the printer is plugged into. However this computer must always be on for you to print from any other remote computer.
Jul 07, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
I was unable to print to a local printer from xp remote desktop, printer connected with a parallel cable. Local printer not displayed from remote desktop. Kindly assist?. The printer is HP Laserjet 2420.
FIRST THING TO CHECK IS IF THE PRINTER IS DISPLAYED IN THE PRINTER WINDOW IF SO RIGHT CLICK ON IT AND GO TO PROPERTIES THEN TO THE PORT SETTINGS AND MAKE SURE IT HAS NOT BEEN SET TO USB OR TCPI PORT YOU CAN SCROLL DOWN AND MAKE SURE IT IS SET TO LOCAL PRIINTER THIS WINDOW AT GENERAL SETTINGS WIL ALLOW YOU TO PRINT TEST PAGE AS WELL
Jun 11, 2009 | Sharp AL-1642CS Copier
Setting remote desktop to xp pc from vista laptop
By default in Vista Remote Desktop is disabled.
Steps to enable Remote desktop:
1. Press Window Key + Break Key and it will display the system properties.
2. On the system properties click on the remote tab and on the Remote Desktop Options tick Allow connections from computers running any version of Remote Desktop.
3. Click Apply and OK
Apr 18, 2009 | Computers & Internet
649 people viewed this question
k24674
jasbo
jasbo
