Question about Optoma UHP 120W Replacement Lamp Projector Lamp for RD65 / RD65H / SV65HF Projection TV
Attempting to get a Vivitek UHP 120W Lamp...for a Vivitek 51" TV
The Vivitek 51" Micro display projection TV requires a UHP 120W Lamp. I do not seem to be able to find one for Vivitek but I have seen a couple of others. Does it matter what the brand is as long as its a UHP 120W Lamp?
How much is a uhp lamp 120w xl-5100
Original lamp USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jul 24, 2014 | Sony XL-5100 Projector Lamp for Grand WEGA...
What is the dlp lamp number for Samsung HL61A750A1FXZA
I am not so sure , because difference engine difference lamp.
Make sure that lamp same with spec in your TV set.
BP47-00023A , LAMP;UHP 120W/132W 1.0,E22,65*70,LL
BP47-00018A , LAMP;UHP 100W/120W 1.0,E22,65*70
BP47-00041A , LAMP;300W PHILIPS LAMP,200MM,56*56,132W,
Thanks.
Apr 05, 2011 | Samsung 61" Slim-Depth DLP HDTV
Three green lights and two orange light blinking
One of them "LAMP" LED light indication is blinking?Yes,mean ur tv projection lamp life is over.Tv projection lamp been inside this tv like 1 1/2 or 2 year and tv been on and whatches like 4 or 5 hours of tv daily?Yes,to all these mean ur tv projection lamp require replacing.
Jan 13, 2011 | Vivitek V37655 56" DLP TV
Blured picture on thomson projector tv
If cocusing teh projector is not working, try cleaning the lens. Sometimes dust is dislodged when replacing a lamp and coats the optics.
Jun 27, 2010 | Optoma UHP 120W Replacement Lamp Projector...
Looking for the enter code for vivitek tv model # rp51hd41-a a 51" micro display projection tv
your cable or satellite will do just fine. i have a vivitek rp51 and i was told that if i lost my remote i was SOT well i found out that the parent company of vivitek is DELTA and wouldn't you know it i programmed my direct tv remote using the brand delta wich was on the list and it worked... by the way vivitek is not on any list for remote control codes....
Jan 14, 2010 | Vivitek V37655 56" DLP TV
The indicator light showed our 51" vivitek projection tv needed a new bulb. We bought and installed a new one - now there is no picture. The bulb is working - but still no picture.
when you replace the door, after you have reinstalled the lamp, make sure that the button inside the television cabinet is being pushed in by the door. i had the same problem when i first replaced my bulb.
Aug 28, 2009 | Vivitek Televison & Video
Where can i get a replacement bulb for 52 inch by d:sign lcd tv. the bulb reads philips uhp 120w 1.0 101859100
some electronic parts dealers are now selling this part. the actual size of the tv is important to have the real size you need. But the real original part maybe only the manufacture can sell it to you
Apr 17, 2009 | Televison & Video
Finding the right lamp
i found a new original lamp but still wont to find out if it is indeed only a 5 kv ignition most are 15-18kv did not have the customers set at my shop , they just brought in lamp assm.Next set in i'll find out.
Feb 22, 2008 | Televison & Video
I want Top 262 K4, UHP 120 W , 50V lamp.
Go to this link. They have what you need.
http://www.shopbot.ca/p-46336-637756.html
And sorry I have no idea where you can get one that's in India.
Nov 24, 2007 | Optoma UHP 120W Replacement Lamp Projector...
TV picture shakey/blurry
Rachael, The Pioneer PRO-100 is a rear projection 51 inch TV of 1000 lines resolution. I do not know enough about the type of projection to answer this question. They use Liquid Crystal Display panels through which a powerful light shines, or Texas DLP micro-mirrors which reflect the light. As the deflection is digital in nature it does not `die' like a C R Tubed television. Are you saying now it won't come on at all, and shows the red light? I can only think it is like a projector and has fans to cool the lamp. To start with the fan may get squeaky due to a dry bearing (common problem). Eventually the fan will stop or not supply enough air and the lamp will overheat and burn out. They cost 250£ to 450£ to replace.(UHP mercury vapour lamps) In your TV it seems that something in the optics has bad distortion and de-focussing due to the overheated lamp. This could be much more expensive to put right.
Oct 23, 2006 | Pioneer PRO-100 TV
162 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
