Have a1996 gmc truck. the ac wont blow out paneles
  • 6,826 Answers
Hi,May be I can help.Look for a vent door actuator ,to be bad,but look under hood for a vacuum hose or a vacuum check valve to be busted.This is the first thing to check.Look under hood for this problem of the vacuum,check all vacuums,and then look on passengers side of vehicle under hood for vacuum and check valve to be located.If I can help ..roniecon@gmail.com
Posted on Jul 17, 2009
Got a1996 gmc safari when i turn on the heater the fuse blows... its a 20 amp
The resistor is not the likely candidate for a fuse problem. There is either a short in the electrical wiring to the blower motor, or the blower motor itself is faulty, causing the fuse to blow. Disconnect the blower motor from the circuit and try turning it on. If the fuse doesn't blow, it's probably the motor.
Sep 16, 2014 | 1996 GMC Safari
My heat wont blow out my vents just my defrost vents and it wont switch from ac to heat in my 97 gmc jimmy whats the problem
blend door sticking not sure if this year has an electronic actuator for the door or not
Sep 19, 2012 | 1997 GMC Jimmy
2004 gmc yukon xl, rear ac/heat not coming on AT ALL. not blowing or anything. stopped suddenly, and has not come back on. checked all fuses and relays. no problems with the from ac
I will assume the ac is still getting cold, just not blowing.
You wouldn't really know unless you pulled the panel and checked the lines.
Causes include the blower motor, resistor, fuse, or switch.
Jul 06, 2012 | 2004 GMC Yukon
AC compressor will not turn on, and will not blow
open fuse panel under hood and check the AC Comp fuse. If it blows again you may need a new compressor
Apr 10, 2010 | 1999 GMC Suburban
Blower wont blow out ac on 97 gmc jimmy
pop the hood and check to see if your ac pump is turning or just free spinning if it isn't spinning then u might have tripped the low ac pressure switch and may need to be checked for leaks and recharged
Jul 19, 2009 | 1997 GMC Jimmy
Why wont my a\c blow through my vents. it blows on
Vacuum hose most likely the problem. They get dry and crack open especially near the connections. Check the vacuum and listen for a hissing sound with the engine running. Don't put your hands near the fan!
Jul 03, 2009 | 1996 Chevrolet Astro
MY AC WORKS ONLY IN UP PANEL BUT WONT BLOW IN VENTS OR IN HI JUST LOW WHAT CAN BE WRONG WITH IT?
check the switch for the fan it could be the reason why only the high works. You may check on the wiring from the switch and on the fan. It could also be a defective fan
Jun 04, 2009 | 1998 GMC Safari
Ac working but not blowing
look under the dash near the heater vent door control you probably have a small hose off, or; a linkage broken to the actuator
Apr 20, 2009 | 1996 GMC Yukon
2004 gmc sierra 5.3. AC not working AC Compressor fuse blowing
UNPLUG THE A/C CONNETOR ON THE A/C COMMPRESOR. REPLACE THE FUSE AND TURN ON THE SWITCH. FUSE OK . REPLACE THE COMMPRESSOR AND THE RECIVER DRIER.
Apr 17, 2009 | 2004 GMC Sierra
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
