My hp printer says its jammed when their is no paper in it
    Sergeant:
  • 361 Answers
It is jeneral problem of senser, printer should be servising . then it can be work. it means open all parts of printer and (clen and assambl)
Posted on Jul 17, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
How to clear a paper jam in my printer?
  1. Turn off the machine, and unplug the power cord of the machine from the power supply.
  2. Open the paper output cover. ...
  3. Make sure that the jammed paper is not under the FINE cartridge holder. ...
  4. Hold the jammed paper with your hands.
  5. Pull the paper slowly not to tear it, then pull the paper out.
to know info SAF 2507 pipe fittings
May 20, 2016 | HP PSC 950 All-In-One InkJet Printer
I have a hp deskjet 3940 colour printer,there is paper jam error,so what i could do to solve the problem
Follow these steps :
1.1
Take out any paper that is not jammed. Remove the loose paper from the in and out paper trays to prevent any more paper from being pulled into the jam.
2.2
Open the cover of your HP laser printer. This will give you access to the inner machinery of the printer and should unveil the jammed paper. If you do not see jammed paper, you may have another type of malfunction.
3.3
Gently pull on the jammed paper. In many cases, it will come out easily.
4.4
Move the rotors on the inside of the printer by pressing the flashing button on the housing of the printer. This may help to loosen any jammed paper.
5.5
If the jam persists, unplug your HP printer. You'll be able to pull more firmly on the paper with the power turned off. Be careful not to rip the paper.
6.6
Attempt printing again. Refill the trays with paper and plug your printer back in to test its functionality.
Oct 30, 2010 | Office Equipment & Supplies
Hp Officejet L7480 false paper jam message. Resetting the printer has no effect.
Hp paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
May 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My hp laserjet 1150 series stops printing after a paper jam
you probably have a piece of paper inside printer or you have damage a paper sensor path while removing jammed paper.
Jun 22, 2009 | HP LaserJet 1150 Printer
False paper jam on HP Office Jet V40
hp officejet v40 indicates a paper jam and it is cleared nothing
Apr 04, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Continual Paper jam HP Officejet 6310
There's a couple things that can cause recurring paper jams. Most often, all the pieces of the jammed paper aren't removed. This video shows you where to look to find all the jammed paper. It also offers some other solutions as well. If the solutions in this video don't work, the printer is likely broken.
Jul 07, 2008 | HP Officejet 6310 All-In-One InkJet...
Printer jam
hve u tried removing the paper jam from a proper place.hp has provided a door behind the printer to clear paper jam.open that door n check out 4 any paper part left out in it.wish u success
May 31, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
51 people viewed this question
jasbo
jasbo
