The notebook acer aspire 5520 will not turn on The power light flickers on and off. However the screen remains black.
  • 3,741 Answers
Its a power supply problem.either the inner fan is getting blocked and due to the dust and due to this power supply is getting hot and the unit is not turning on and just blinking.or the power supply is faulty.if under warranty get it replaced.if not open the unit from its back by removing its screws with a screw driver.remove all the removable parts and clean the unit internally with a soft brush and refit all everything as it was and check out .many a times this solves if its dust problem.other wise new power supply required.also remove the battery and connect the unit directly to the wall charger and check out by turning it ON.if it starts without battery directly then its a battery problem.it runs without battery by directly connecting it to wall socket. you can get it at www.radioshack.com Please do rate the solution. Thank you for using fixya.keep updated. thanks
Posted on Jul 17, 2009
Hi, I have acer aspire 5520,2 Gb RAM... When I turn on my acer,everithing works just fine,exept monitor,it remains black,When I try ecternal monitor,it works fine,windows wors fine to,everithing but the...
Aspire 5520 has LCD Display. The screen displays becomes dark/ dim if there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. These parts are inside the LCD screen. Either of the parts may be faulty or in some rare cases both. Also, the video data cable may be loose or faulty, which can be identified only after opening the top cover.
So, my advice is that you get it properly checked by any professional for replacement of Inverter or CCFL.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 22, 2011 | Acer Aspire 5520-5579 Notebook
I have an aspire 5810tz power light comes on but the screen stays black, how can I fix it
remove and clean lan card and memory....then try to put it again and start your computer...
Feb 02, 2011 | Acer Aspire 5520-5908 Notebook
My Acer Aspire 5520-5141 is screen is black it will not turn on. It has been in and out of the shop for repair.
--did they tell you what they did each time you sent your notebook to them ?
Sep 14, 2010 | Acer Aspire 5520-5908 Notebook
I have an acer notebook. model aspire 5520. what
Simply press the WiFi on/off key (it's the first key from left to right, between the "Power" button and the laptop's keyboard). A message should appear on the screen telling about the WiFi adpter's state (on or off).
Glad if I could help!
Jan 25, 2010 | Acer Aspire 5520-5908 Notebook
Acer aspire 5520g black screen, power light blinking
go to acer website ...go to dowloads section..select ur model ..n download latest bios
Nov 06, 2009 | Acer Aspire 5520-5908 Notebook
Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Aug 16, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire 5520 one black screen cursor
TAKE OUT BATTERY, REMOVE MAINS SUPPLY, HOLD POWER BUTTON DOWN FOR 30 SECS PUT POWER SUPPLY IN ONLY DO NOT PUT IN BATTERY TURN ON LAPTOP NOW PUT IN BATTERY
Jun 06, 2009 | Acer Aspire 5520-5908 Notebook
Brand New laptop, won't start
Try taking the battery out before you turn it on. Have seen completely a dead dead battery keeping a laptop from starting up. Does the hard drive activity light flickering? If it is you can try holding down the Function button (FN) and there should be another button to hit to switch between LCD\CRT.
Mar 01, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520
check if dvd drive will eject if not
if it doesnt - try another socket
if still gets nothing - change fuse in plug
if same - try another power adapter (preferably from same manufacturer and model)
If still doesnt get power try get new power supply unit from repair shop or get quote for cost to fix
Jul 20, 2008 | Acer Aspire 5520-5908 Notebook
16 people viewed this question
jasbo
jasbo
