Question about Whirlpool LSR9434PQ Top Load Washer
Whirlpool mod.#LSR8233JQO doesn't spin out all the way, I know it's a cuplink prob. but can't find a parts manual online to see where it goes and what it looks like so I can fix it, can you tell where to get online parts manual?
    President:
  • 1,136 Answers
Hi, Here is the instruction for the coupler. I will se if I can get a picture and send it in next comment.
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
Vic
Posted on Jul 17, 2009
  • Victor
    Victor Jul 17, 2009
    Here is a picture to helps you see where it goes. The coupler is # 13 in the picture. The part # is 285852.
    Please let me know if this helps you or if I can assist you further.
    Vic
Our Whirlpool dishwasher (mod. #DU1055XTVS0) turns on but it's not getting the dishes clean. It also seems as though the top spray bar is not spinning. Is there a filter or something that's clogged?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 20, 2011 | Whirlpool DU1055XTVS Builtin Dishwasher
Kenmore Mod.#11027831600. When in spin cycle the washer shakes and move around the floor. I check that it is level. And that the clothes were in the evenly.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27831600&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Aug 06, 2010 | Kenmore 27831 Top Load Washer
Washer will not drain or spin
sounds like the timer has failed...try manually selecting spin mode...that should give a indication.
Jul 21, 2010 | Whirlpool Washing Machines
My Kenmore 90 series won't sping fast.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20902991+
See number 28 in the control panel section.
Also see the Whirlpool PDF Operating and maintenance manual for top load direct drive washers.
It's quite likely, since the gentle spin works, that the "spin speed switch" is defective. Part number 3953144
Sep 27, 2009 | Kenmore Washing Machines
Washer leaves the clothes very wet. Drain has been
What you have is a broken drive coupling. When the washer goes into spin the pump does its thing but the tub does not because the drive coupling is broken.
SOME REPAIR PICTURES WITH
REPAIR MANUAL
Aug 28, 2009 | Whirlpool LXR6432JQ Top Load Washer
Whirlpool Top Load Washer LSR8233JQO no spin & no drain
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 11 (part #3949247) and the lid strike will be listed as item number 20 (part #358684). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool lsr8233jqo - will not spin
if you hear the motor running then it is most likely the direct drive coupling between the motor and transmission. part #285753 you can see it from under the machine.477922b.jpg f3941f5.jpg
Jul 16, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool LSR8233JQO
The pump is coupled to a motor that runs it. The pump is ok if it is not leaking. You need to check the signal to the motor to turn on. It all comes from the timer switch unit. The coupling probably should be relpaced if the pump is really bad. Sounds like the drive motor for the tub, not the pump, or the switch unit.
Mar 24, 2008 | Whirlpool LSR9434PQ Top Load Washer
Whirlpool LSR9434PQ Top Load Washer Logo
337 people viewed this question
Dan Webster
Dan Webster
Sal De
