Question about Samsung HCM4215W 42" Rear Projection Television
HLT5075SX/XAA DOESN'T WORK EVEN AFTER REPLACING THE LAMP.
After replacing the lamp, the tv stayed on only 10 mins before the LED lights started flashing again. The door is closed properly to engage the door switch, the lamp is brand new & the fan seems to be working just fine. Am I overlooking something?
  • 304 Answers
If you are not hearing a whining noise coming from the color wheel then you have a bad Ballast. Part# BP47-00037A.
Posted on Jul 17, 2009
I have a Samsung DLP HLT5075SX/XAA and I just replaced the bulb. The tv comes on but it's white with tiny black specs and and two thick black lines going across the bottom. There is no sound but...
The lamp should get very hot---make sure fans are running.
If you happen to remove the lamp---look at the color wheel that faces it to see if missing any pieces--it will before failure make a high pitched or even fan like sound.
You may have a problem in the light engine or the board often called the DMD which is part of the engine.
Jun 13, 2012 | Televison & Video
Panasonic 60" LCD Projection TV Turns off every 1-2 hours
What is the model# of your TV?
Do you see any blinking (LED) lights on the front of the TV?
How many blinks?
Which LED light is blinking, Power, timer or lamp?
Nour Sabre
www.aaatvservice.com
Nov 15, 2011 | Panasonic Televison & Video
Have a 50 inch samsung projection tv model hlt5075sx/xaa lamp code bp9601653ap132w turn tv on lamp stays on for approx 20 seconds then 3 blinking lights on right bottom side start blinking if it is the...
The blinking lights will be flashing a code.....
Can you please indicate the sequence of the flashing lights, as this will determine what needs to be done to fix your fault.
Cheers,
Jun 16, 2011 | Samsung - Projection TV replacement lamp...
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Aug 02, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Aug 09, 2009 | Samsung HCM4215W 42" Rear Projection...
I replaced the bulb on my Samsung DLP projection TV (HLT5075SX/XAA) but now there is a plastic burning smell. Does anybody know what it can be?
That is probely the smell of the new lamp. If the odor persist and gets worse then remove the lamp and inspect it and the inside of the tv.
Jul 08, 2009 | Televison & Video
Samsung HCM4215W 42" Rear Projection Television Logo
1,795 people viewed this question
Jerry Greenberg
Jerry Greenberg
