Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
I have a 18" Intex pool and I need directions for hooking up the pol's vaccum. The pool was given to me.
  • 297 Answers
The easiest thing to do is watch the video
all pumps and vaccum set ups are basically the same
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Posted on Jul 17, 2009
  • 76 Answers
Hi
the tricky part is to avoid air from coming into the vaccum pipe and from there to the pump .
1. the first thing you got to do is fill the pipe with water .you can do that easly by putting the vaccum pipe next to the outlet water exit while the pump is working till you see that there is no more air inside the pipe .
2. connect the pipe with the cone to the skimmer , at this stage you might get some air inside the pipe but don't worry .
3. once all part are connected and the vaccum head is in the water activate the pump and open the top screws on top of the pump and the filter to realese the air that might have entered the pipe .
once the air is out and the vacuum works close the screws and you are ready to go .
enjoy
What would be the best automatic pool cleaner for intex 18 x 48 easy set
try to get the vacuum that works with the garden hose they work ok for the small pools
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
Free Chlorine won't register in pool?? I have done everything the manual suggests and cannot get a reading on chlorine from my pool. If you check the water coming directly out of the generator it...
if getting reading from unit and losing by the time it gets to pool water chlorine is locked need to add non chlorine shock to oxidize and super shock pool
Sep 02, 2017 | Intex Automatic Salt Water System for ...
My plunger valve for the outflow hose broke. What can I do until I can get another one
Just remove the plunger assembly and hook the hose directly to the nut on the outside of the pool wall.
Jun 05, 2011 | Intex Plunger Valve & Straniner Basket set...
Need a diagram to hook up my pump
Go to www.intexcorp.com. Select your location from drop down. Click on "Need replacement parts or Accessories for Intex Products", under the Consumer Info heading near bottom of the page on the right side. Click on " Instructional videos and manuals', on right side. Click 'product set up manuals" and chose your filter. Hope that helps!
Jun 03, 2011 | Intex Ultra Metal Frame Pool w/ Upgraded...
I have an intex 15 x 48 pool. The old pump wasnt
check the intex site for adapters and other parts you might need.
I don't think you should buy new pool .
Jun 28, 2009 | Intex 4000 GPH Filter Pump
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex pool pump directions
from skimmer one hose goes into pump. outlet goes back to pool
Jun 16, 2009 | Intex 4000 GPH Filter Pump
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
253 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
