Check this two procedure for...
2.2L (VIN 4) Engine
Properly discharge the air conditioning system into a
recovery/recycling machine.
Remove the drive belt on the vehicle.
Remove the air cleaner and resonator assembly.
Unplug the electrical connections from the compressor.
Disconnect the negative battery cable.
Unfasten, then remove and cap the A/C hose from the compressor.
Cap the refrigerant lines when opening the system to prevent the
entry of dirt and moisture and the loss of refrigerant lubricant.
Loosen the A/C compressor bolts, then raise and support the
vehicle.
Fig. 3: Compressor mounting on the 2.2L (VIN 4) engine
Remove the compressor.
To install:
Position the compressor on the vehicle.
Lower the vehicle.
Install the compressor bolts, then tighten the front bolts to 37
ft. lbs. (50 Nm) and the rear bolts to 22 ft. lbs. (30 Nm).
Attach the compressor hose using NEW sealing washers. Tighten the
mounting bolts to 24 ft. lbs. (33 Nm).
Lubricate O-rings with refrigerant oil.
Engage the electrical connections to the compressor.
Install the air cleaner and resonator assembly.
Install the serpentine drive belt.
Connect negative battery cable.
Evacuate and charge the system.
Perform a leak test on the system.
3.1L (VIN M) Engine
Remove the serpentine drive belt.
Remove the front compressor bolts.
Raise and safely support the vehicle.
Remove the rear compressor bolts.
Fig. 4: Compressor mounting on the 3.1L (VIN M) engine
Unplug and cap the coupled hose assembly from the rear of the
compressor.
Disconnect the electrical connection at the compressor.
Remove the compressor from the vehicle.
To install:
Install the compressor on the vehicle, engage the electrical
connection to the compressor.
Install the coupled hose assembly to the rear of the compressor,
with NEW sealing washers. Tighten the mounting bolt to 24 ft. lbs. (33
Nm).
Install the rear compressor bolts. Tighten the rear bolts to 8 ft.
lbs. (25 Nm).
Lower the vehicle.
Install the front compressor bolts. Tighten them to 37 ft. lbs.
(50 Nm).
Install the serpentine drive belt on the vehicle.
Connect the negative battery cable.
Perform a leak test.
Hope this help (remember rated this).
