SOURCE: 1994 caravan...transmission problem?....speed output sensor ?
I changed the transmission control module, located on the firewall on the passenger side under hood. Now the transmission works fine. Bought it at pull a part junk yard for 20.00 and thought what the heck I will try this. It worked.. amen
SOURCE: 95 dakota dies when warmed up
yes it can but you may have a coolant temp sensor acting up which causes the computer to open the injectors to much which can also cause this 02 sensor code. when it stalls do u have spark and fuel pressure.
SOURCE: engine shuts off/ loss of power under load
usually ignition coil will cause you this grief obd 2 scan your engine light to confirm nature of your misfire
SOURCE: engine seized driving down road, now won't even turn over
The 3 liter mitsubishi is pretty prone to this actually. You would have to tear it down to see what happened, but yes it's likely that you have a bent valve and/or hole in the top of a piston from a valve.
SOURCE: Starts up like normal but
P1294 indicates a vacuum problem or a idle motor control problem. Since you already checked for vacuum leak then the iac on the side of the throttle body will need to be removed and cleaned. The best thing to do is remove the whole throttle body so it can be cleaned as well - both with carb cleaner. The idle solenoid (motor) on side of throttle body should be removed to do a through cleaning. All of the black needs to be removed from inside both before remounting to the intake. Make sure all connections and bolts are tight before starting engine.
