Question about Acer AL1916W 19" LCD Monitor
No image on the monitor
When the computer is turned on, everything happens like it used to but the monitor is on and there is no image. Every now and then the image will show but it will not stay on it goes back to black. This is an Acer 19 inch LCD monitor.
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 17, 2009
  • Acer Master
  • 497 Answers
Perform a Monitor self-test:
  1. Turn off the monitor.
  2. Disconnect the video cables that connect the monitor to the computer.
  3. Turn on the Monitor.
  4. The appearance of color bars indicates the Monitor is functioning properly.
  5. If the color bars fail to appear then issue is with the Monitor only and service will be required.
  6. If the color bars appear then issue may be with the Video Card of the Computer or with the Computer itself.
  7. Try installing the Video Driver using another Monitor or try installing the Operating System to determine whether the issue is Hardware related or Software related.
Why does the monitor not display when the computer is turned on? It comes up with Analogue Powere Saving Mode and then blank again? I have rectified it now after 36hours hassle. Can you tell me what to do...
The only thing that comes to mind is pushing the source button on the monitor, or finding the source option in one of its menus. If it is on analog and is not displaying an image, you may have to switch it to Digital or DVI, depending on what type of cable you're using to plug it into the computer. Though this is usually auto detected by the monitor when the computer is turned on, unfortunately there aren't many options when dealing with a monitor that refuses to post an image.
May 29, 2011 | LG Flatron L1750S 17" LCD Monitor
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
No image from MacBook Pro
what happens when you go to monitors in syst prefs? have you tried another monitor ? (make like you want to buy one, take your pro in and try it out) what leads are you using?
Dec 03, 2009 | Sony SDM M81 18.1" LCD Monitor
No image on monitor
Looks like the Video card, or Video chip has bought the farm
Try hooking up to another monitor to confirm where the problem is.
Jan 30, 2009 | ViewSonic VX922 19" Monitor Flat Panel
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Monitor is Flickering and screen becomes pink
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it goes back to white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 10, 2008 | Acer AL2017 20" LCD Monitor
Monitor Generated Image
Great picture! Big problem! i suggest is time to do a monitor change.
Sep 17, 2007 | ViewSonic VX910 19" LCD Monitor
Screen does not maximise automatically
reinstall the driver for your monitor or adjust the resolution in the desktop properties
May 14, 2007 | LG Studioworks 700S 17" CRT Monitor
Acer AL1916W 19" LCD Monitor Logo
221 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
