Question about Breville Die Cast 800ESXL Espresso Machine
Power light will not come on.
We recently went to use our new Breville espresso machine and after filling the water tray, attempted to turn the power on by pressing the power button but nothing happened. We checked the power source (ie. plug in) and it was working fine. We suspect that someone turned the power on when there was no water in the tray and possibly burned out the elements. Where can we find a manual to disassemble the machine and locate a reset button or replace the heating elements?
  • Anonymous Nov 21, 2007
    Same thing happened to us this morning. Just in time for thanksgiving. Customer Service was useless. They gave me a number to a service shop here in Manhattan which doesn't sound to promising. If I hear anything back I will let you know asap.
  • Phyllis w Mar 04, 2013
    Does anyone know if there is a reset button before I throw it in trash?
There is a post with a solution for this with the title: "Machine won't turn on - no power! " - fixmebob has a good solution, but you'll need to be a little tech savvy to perform it yourself. I ended up sending mine in for repair, which ended up being about $55 because I had to ship the machine. But good news is that I'm back up and running.
Posted on Jan 21, 2008
When turned on for heating the water does not stop flowing into drip tray
When you say the water does not stop flowing? when you are in steam or hot water mode?
Apr 16, 2016 | Breville Die Cast 800ESXL Espresso Machine
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
After successfully using the machine I tried to make a second coffee. Water continually poured into the tray and the machine sounded very loud (as if it was starting up). I then tried to shut down the...
The coffee grind is too fine, or you are tamping too hard, First remove the portafilter and press the brew button if water flows move on if not remove the shower and clean. Now that we have a nice flow of water without the portafilter. Now we will add coffee to the portafilter, and level it out, do not tamp and try to run a coffee, if that works then the Tamp is the problem, if you tamp and still have the problem then the grind is too fine.
Jan 02, 2011 | Breville BES820 Espresso Machine
Although machine is turned off water pumps through to the over flow tray(power button is not pushed on )
Sounds like a check valve on the pump or the power switch is not operating properly, if off and pump is still working.
Mar 07, 2010 | Breville Die Cast 800ESXL Espresso Machine
Breville Aroma Style wont turn on
looks ur on and off switch is faulty......bring the machine back where u got it from and if under warren tie ask for a new one
not sure how long u got this machine....
Jul 03, 2009 | Krups Small Appliances Espresso Machine
Leaking Breville Esp6
sorry this is out of my leage someone elso will have to help.
May 16, 2008 | Breville ESP8XL Espresso Machine
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
No water is being pumped at all
Good Luck!
Nov 04, 2007 | Breville Die Cast 800ESXL Espresso Machine
Hot water won't flow into machine
You most likely need to prime the brew head. Follow the instructions in the owner's manual. To prime the brew head, you'll need to put run the machine without coffee until water starts flowing. One water flows, the brew head is primed and the machine is ready for normal use. You'll need to do this every time you run out of water. Regards, Denis
Oct 09, 2007 | Breville ESP8XL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
448 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
